LG 42LC46 problem
+ More Options
Posts
  • sienoki
    sienoki
    • Jan 2012
    • 314
    LG 42LC46 problem
    Hi guys n gals..im a newbie here so a big hello n happy new year.
    I bought this model lcd tv from a friend ..it was completely dead..after opening it up there was 4 10v 2200uf caps bulged..so i replaced them with rubycon same values.It powered up fine and worked ok for 10mins then the picture would go but sound remains..the backlights would also stay on.
    If i take the t-con board out then turn on i get the same result no picture only sound..could replacing the t-con board fix my issue..any help in my matter would be greatfully received..thx
    Re: LG 42LC46 problem
    I repaired this same TV (it's now my main TV.) It could be T-con, but double check your soldering on the capacitors is good. As the TV warms up, maybe the joints are cracking. Does the TV give a good picture for 10 minutes at a time? Try using a hair dryer to localise the fault if it is heat related. Also double check the LVDS connector is seated properly.
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Hi tom thx for answering back..am fairly sure solder joints are good i will check them again..yes i get a good picture for 10mins at a time..the LVDS is seated firmly in..Im totally new to electronics but have repaired 3 lcds been lucky they where only bad caps..think im gonna order a t-con board..theres only 1 on ebay thats from a smashed screen and he dosnt state thats it been tested so might take a chance on it..How would i use the hairdryer to localise the fault..thx
        Get out the hairdryer, heat up individual areas around the capacitors, T-con and main board, if the fault shows then turn it off and test again, if it shows again then you have found the suspect area. Good for finding cold joints and bad capacitors (which don't always bulge.)
        • sienoki
          sienoki
          • Jan 2012
          • 314
          I checked the solder joints and they are all good..i tried the hairdryer on t-con and main board with no results..ive changed 9 caps on psu from 35v downwards..would you also reccomend replacing the smaller caps on psu that are above 35v they also them crap named 1s..can t-con boards work for 10mins and just fail..thx
          I bought a cap..diode tester from farnells on clearance shelf but dosent even work..i have a standard multimeter..thx
          • sienoki
            sienoki
            • Jan 2012
            • 314
            Hi..i have since replaced all caps on my psu..after 10mins still same so i then left it on for 30mins and picture is like photo..if i buy this t-con card and still same probs could some kind and patient soul walk me through how to use my multimeter and where to start as i am totally new to all this..thx
            sos for crappy pics..
              What capacitors did you use to replace the originals?
              It could be a T-con fault. I've got a Samsung on my hands at the moment that has lines on the screen with no image visible, but sometimes after it warms up the picture comes back. I suspect the T-con is bad. It's possible, although unlikely, that bad caps could damage the T-con.
              Can you list the ranges/settings your meter has - does it have a 20V or 40V range?
              • sienoki
                sienoki
                • Jan 2012
                • 314
                ZL series of rubycon-ultra low impedance 5x10v-2200uf
                the others are rubycon aswell apart from 2 panasonics 10v-470uf and 25v-47uf
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  I met a bloke at farnells today in Leeds..he said he was a mod on here but didnt get his name as our lass was left outside for 30mins
                    Okay, those caps are fine.
                    Set the multimeter to the 20V range and measure all the outputs on the power supply.
                    • sienoki
                      sienoki
                      • Jan 2012
                      • 314
                      I will have to start my test another time as i use my bed to put tv on and now r lass is asleep in it..thx 4 ur help
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        The replacement t-con arrived today..installed it but still no joy
                        I wont pretend i know what im doing cos i dont..i feel im learning quite abit from other threads and definateley apreciate your help so far.
                        Now its time to start with my multimeter..on my psu there are 3 pin outs together..2 with the block wires going to the main board and 1 not in use..is that the test pin out..if it is i took readings when the unit is powered on(scary)as i dont to blow myself up..anyways readings are as followed
                        3.4v=3.47
                        GND=0.00
                        6.5=6.33
                        GND=0.00
                        12v=12.25
                        GND=0.00
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          3.4v=3.47
                          GND=0.00
                          6.5=6.33
                          GND=0.00
                          12v=12.25
                          GND=0.00
                          should i now take readings from the other 2 pin outs..if so do i need to take the block wires out and take readings with the set switched on..thx
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            3.4v=3.47
                            GND=0.00
                            6.5=6.33
                            GND=0.00
                            12v=12.25
                            GND=0.00
                            this is the picture after 20mins
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              Can any1 help me test further plz..i have 90quid in this set and would be a shame to get rid..thx
                                Post a close up picture of the T-con... you may need to remove the shield.
                                I have a Samsung that has a strange picture occasionally, caused by a dodgy LDO (voltage regulator.)
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  I will have to borrow a decent camera as mine is crap
                                    Even a crap picture might be enough to identify regulators on the T-con...
                                    Here are what regulators look like. The three leg + large tab black devices are LDOs. In this set they are adjustable regulators, all of which are set to 2.5V.
                                    The bottom one on this T-con failed, causing various colour lines on the screen + no visible image.
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      this is best pic at mo
                                        See my edit...
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
