LG 42LC46 problem
  • Scoots
    • Jul 2015
    • England
    #81
    Re: LG 42LC46 problem
    I Know this is an old thread but I had the same problem as the OP. The TV would power on when cold but after 2 mins the picture would go off, sound and back light still on. Using the hairdryer trick I thought I had found the problem C954 - 470uF ( top left corner ) I changed that and all was well. So I thought, the TV did not go off. I left it on for about 1.5 hours then turned it off and on again, no picture again. Having scoured the internet I found a site that offered a repair kit for for such problems which showed the capacitor numbers. I changed C975 -100uF ( near T-Con connector ) the TV seems to be working as it should :-).
    The capacitors listed on the site are.
    C553 - 100uF
    C901 - 100uF
    C915 - 100uF
    C954 - 470uF
    C970 - 100uF
    C975 - 100uF
    I hope this helps other people with the same problems
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #82
      C553 - 100uF
      C901 - 100uF
      C915 - 100uF
      C954 - 470uF
      C970 - 100uF
      C975 - 100uF
      Thank you sooo much this helped me repair one I have
      • THXFX
        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
        by THXFX
        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
        I check capacitors and diodes and didn't find any short IN MAINBOARD.
        Measured all power supply...
        03-20-2024, 03:21 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
