Hitachi P50H4011 Plasma no picture
  • dukesaskatoon
    • Dec 2011
    • 17
    Got a 50 inch hitachi plasma p50h4011 with no picture but sound works.
    On inspection two swollen caps on power supply and a blown chip 3294f on the lower sdr buffer pwb. When i dissconnect the lower sdr pwb I get the top half of the picture back. I will replace the caps on the power supply and the buffer chip on the sdr-d pwb but i am wondering if there is a chance that the pwb (y-sus i think) that the sdr pwb connects to could be damaged as well?
    Re: Hitachi P50H4011 Plasma no picture
    Does the TV power up with the suspect buffer removed?
    • dukesaskatoon
      • Dec 2011
      • 17
      yes i get the top half of the screen back
        Replace the caps and put in a new buffer. Then enjoy your new TV.
        (The buffers are both common, if the Y-sus is faulty, both buffers will usually blow...)
        • dukesaskatoon
          • Dec 2011
          • 17
          Replaced the caps on the lvps and replaced the lower buffer pwb and all is well. too bad that there is a half inch black line at the bottom of the screen must be the panel itself. still good for watching movies though. Thanks for all your advice great forum!!!
          • ajshoe
            ajshoe
            • Dec 2012
            • 477
            • usa
            if you re-connect the lower pwb a couple of times - picture will be correct. These connectors take some fanaggling to get correct.
            • Ree_zalino
              • Sep 2014
              • 3
              Hi folks,
              I got this Hitachi P50H4011 plasma Tv w/ exactly the same problem as in this thread.
              My question is, if one of the sdr board got busted, does the other sdr board need to replaced too ? How about the Y-sus board ? will it perform as good as before the busting of sdr bd.. Can it be affected too?
              Any comments and replies are really appreciated.
              Thank you so much in advance guys.
              Ree
              • Videojoe
                • Sep 2013
                • 47
                • Us
                I fixed two of these and the first one needed only the lower scan buffer and the second one only needed the upper. Both sets needed the same two caps replaced on the power supply board. The y sus boards are pretty tough in these things.
                • Ree_zalino
                  • Sep 2014
                  • 3
                  thanks Videojoe for the info.. it helped me a lot.
                  Kind regards
                  Ree_zalino
                  • instarep
                    • Jul 2014
                    • 28
                    Had the same problem, ordered the lower buffer board from Ebay. It was saying OEM original board but when received it was written '' Made in China'' instead of made in Phils... Can't hide that it was'nt working for me. I have black horizontal lines thorough the image on the bottom part. Could it be something i missed ? How can i know if it's y sus or the buffer board? adjustment ? I will continue to browse for this but in the meantime any good advice is welcome.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      sounds like its associated with a missing data feed to thepanel because of a misaligned ribbon cable connecting to the buffer board. Check that out first and make sure that both are seated perfectly into the connector before Closing the cable connector
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        of course yes it can always be and IC on the buffer board bad ordered soldered on properly
                        • Shinju
                          • Mar 2014
                          • 1239
                          Did you make sure to seat the buffer ribbon cables properly? These are a PITA to do you need to make sure they click 2 time for a solid connection.
                          I had this problem on the upper working buffer on my Tachi as soon as I reseated the cables properly the lines were gone..
                          • Videojoe
                            • Sep 2013
                            • 47
                            • Us
                            Not sure if you fixed those horizontal lines yet or not, but I'm not kidding when I say it took me 5 or 6 tries to get those ribbon cables seated properly. I needed a lot of light and a magnifier lens for these old eyes. You will see tiny plastic tabs on the ribbon cable itself. They have to be inserted perfectly straight into the slots inside the connector.
                            • Videojoe
                              • Sep 2013
                              • 47
                              • Us
                              Oh and don't forget to turn the power off every time
                              • Rex
                                • Jul 2010
                                Re: Hitachi P50H4011 Plasma No Picture / No Sound.
                                Missing Va & Vs voltages,,, but if I remove the upper & lower buffer boards, voltages return!
                                Both buffer boards are "good", positive.
                                If I remove the supply power cable to the YSUS (8 wire) still no Va or Vs.
                                Is it possible the YSUS board is bad?
                                Any help is appreciated...
                                Thanks Everyone.
                                • beaven24
                                  • Aug 2015
                                  • 7
                                  Rex, did you ever figure your problem out? I have a different model Hitachi (P50S601) but a similar issue. Only a low 3.8V Va and Vs voltages from the PSU and both of my SDR buffer boards test good. Blue light stays lit (no flashing). Tried a different PSU but no change. Thinking about trying a new Y-SUS next but wanted to see if you had any luck. I have sound but no picture but my Va and Vs don't return if I remove both buffer boards.
                                  • R_J
                                    • 9624
                                    when inserting the ribbon into the connector, make sure the tab on the ribbon is ahead of the white block on the connector and the side of cable is beside the white block, on both sides. you will usually need a magnifier to to see it but when done right you should not get any thin lines
                                    • Yanleb
                                      Schematic or datasheet for Plasma TV buffer chip
                                      by Yanleb
                                      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                      05-18-2022, 01:36 PM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • KYBOSH
                                      Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                      by KYBOSH
                                      Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                      No picture but you hear the TV static (white noise) playing loud and clear.
                                      The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                      But it seems they didn't get too far and just left it.
                                      When I first took a look I was amazed at how pristine the inside looked.
                                      Its as if the TV had been in a time capsule.
                                      Caps looked like they were just pulled off the self.
                                      Copper coils had no sign of corrosion on...
                                      02-01-2023, 11:10 PM
                                    • KYBOSH
                                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                      by KYBOSH
                                      Saved this beast from the landfill this weekend.
                                      Manfactured July 2013 in Mexico.
                                      I love working on plasma TVs.
                                      Its been a while but I was lucky enough to find 2 this week.
                                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                      Will start troubleshooting tonight.
                                      10-17-2024, 01:17 PM
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
