Matsui LM20N2 inverter problem
  • bbjunkie
    • Dec 2011
    • 301
    This set came into my possession stuck in standby, would switch on for a second or so but no picture or sound, then switch off again.
    After doing a bit of research on the web I discovered that I might have some blown transistors right before the inverter transformers which there are four of on the board (see attached pic with two transformers and 4 of the transistors removed for testing) There are two of these 2SD965 transistors per transformer.
    Long story short, I pulled and checked two of the transformers for short circuit, they both tested the same (0.6 ohms on primarys and 370 ohms on secondaries) so I assume they are fine.
    I refitted the transformers and removed the transistors Q7 thru Q14 and tried to power up, the set came on and stayed on - I had audio (obviously no video)
    Fitted the new transistors and powered it up again, thought I had cured it, it came out of standby for about 5-6 seconds then there was like a crack noise that sounded like a component blowing around the top of the tv somewhere (or perhaps it was my new transistors, difficult to say)
    So, now im back to square one.. Am I right in thinking that this must be a CCFL problem as there is nothing wrong with the transformers? Would I do damage if I try replacing the transistors again and leave the HT leads off the tubes to eliminate them? (can the inverter cope with no load?)
    Cheers,
    Jim
    ps again, please excuse the quality of photo - I really need to get better lighting and camera for the workshop
    Re: Matsui LM20N2 inverter problem
    A lot of BenQ monitors have problems with the solder joints around the inverter transformers cracking which kills the transistors... not sure why and not sure if it applies to yours but... Try re-touching all the solder joints around the transformers, and replace the transistors. You can test these transistors for short circuit (they should appear open.)
    • PlainBill
      • Feb 2009
      • 7034
      Also check the blue caps near the inverter transformers. Also check any diodes in the area.
      PlainBill
      • bbjunkie
        • Dec 2011
        • 301
        Nice call there PlainBill - One of the blue caps just south of the inverter transformers was showing well low readings. One measured 350pf while the other measured just 3pf (a resistance test showed it wasn't shorted)
        Both have the same markings so I am confident the 3pf one is faulty.
        Didnt have enough time to do much else today, being dragged out by the missus
        Post more tomorrow
        Jim
        • bbjunkie
          • Dec 2011
          • 301
          Think I need to check those readings.. just realised they should be 27pf +/- 5% -- right?
          Also, seem to be having difficulty locating these components, are they polyester dipped/ceramic/silver mica? or will any 27pf 250v capacitor be suitable?
            no, they are probably 5kV devices. http://parts.digikey.com/1/parts/630...a270kat3a.html
            • bbjunkie
              • Dec 2011
              • 301
              Sorry, overlooked saying the originals were rated at 250v (they are on the primary side of the transformer)
              • PlainBill
                • Feb 2009
                • 7034
                These caps set the frequency for the Royer oscillators. The value can vary with the design, but the one I had die in a Viewsonic (Belinea) monitor was 150nF. Are there any numbers on them?
                PlainBill
                • bbjunkie
                  • Dec 2011
                  • 301
                  Yes, they are labelled 27J 250v
                  • PlainBill
                    • Feb 2009
                    • 7034
                    That would indeed be 27 pF. Strange, that is much lower than I would have expected. I would compare the replacements to the originals with your DMM.
                    PlainBill
                      PlainBill
                      Maybe they are getting away with running them at 700V for about a year before they die - but I would expect immediate breakdown of the dielectric...
                      • PlainBill
                        • Feb 2009
                        • 7034
                        No, there is a failure to communicate. The caps I was referring to are circled in blue in the picture of the inverter. They are the equivalent of C24 and C25 (circled in teal) in the schematic of a different inverter that uses Royer oscillators in it's inverter. They set the oscillator frequency.
                        The blue ceramic caps are usually high voltage (1-3KV) types.
                        PlainBill
                        • bbjunkie
                          • Dec 2011
                          • 301
                          Hi PlainBill, hope you are enjoying the holiday season.
                          The caps you circled are indeed the ones I removed and they are definitely 27J 250V
                          Perhaps this would point to why they have failed? Finding these caps is near impossible. I have found some 500V rated ones, I guess these would do.. or should I go for an even higher rating?
                          Your schematic seems different to my layout.. from memory (and mine isn't great - I will recheck when im in the workshop next) the pair of caps you have circled in my photo are in parallel.
                          Hope to get some better photos up later.
                          Jim
                            Jim
                            250V there should be fine. Heck - the inverter probably isn't powered by more than 24V, so even 50V ceramic caps would do. 250V was probably chosen because it is commonly found on the primary side of power supplies and so is cheaper. Just like 3.579545 MHz xtals are common in lots of things because they are also used in TVs and they are cheaper.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Jim
                              If the caps on the inverter are in parallel, something completely different is going on. Verify the readings you got on the two caps; by any chance was the 350pF actually 350nF?
                              PlainBill
                              • bbjunkie
                                • Dec 2011
                                • 301
                                Caps measured again and are showing 300pf (actually reading 0.332nf on the DMM which is reading 0.032nf with nothing connected) and 24pf (0.056nf on the DMM)
                                With a closer look I have noticed the marking on the cap actually has a . in front of the 27J
                                I googled this item to find a replacement, first hit surprisingly is a thread on another forum about the exact same inverter problem.
                                The outcome of reading this thread is that it has been said they are 0.27uf or 270nf
                                Before I replace these with 270nf can anyone confirm this would be true?
                                Also, checked and they are definitley in paralell.
                                  How big are the capacitors?
                                  A rough order of capacitance can be estimated from size.
                                  From the photo, it looks like it might be in the ~100nF range, way too big to be pF. However, there are other reasons a capacitor might be big including reliability, safety, voltage, dielectric...
                                  • bbjunkie
                                    • Dec 2011
                                    • 301
                                    in the region of 12mm long 5mm thick and 13mm tall
                                      So I would go for nanofarad range, maybe 270nF, they seem too big with that voltage rating to be pF. Just a guess though. The other half of the inverter wouldn't happen to have working caps?
                                      • bbjunkie
                                        • Dec 2011
                                        • 301
                                        There is only two of these caps on the board.
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • stomanata
                                          Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
                                          by stomanata
                                          on my previous post with help from this forum i found short circuit GIF5CH60TS-X
                                          I replace it but again give me error for current over 16A.
                                          I measure again and found short circuit between #15 and #16 (Cin and GND).
                                          On PCB i remove R121 to check in which direction is short circuit. But this pin goed
                                          to big copper piece on back side.
                                          So i try to measure over every resistor and capacitor
                                          But i can`t find any short circuit,
                                          On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
                                          1. Through CSF (i don`t know...
                                          09-15-2024, 02:06 AM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
