Matsui LM20N2 inverter problem
+ More Options
Posts
    Re: Matsui LM20N2 inverter problem
    Originally posted by bbjunkie
    There is only two of these caps on the board.
    Give it a shot then with 270nF. I would like to be more help but I don't have a clue...!
    • bbjunkie
      • Dec 2011
      • 301
      Found some brown caps in my junk box similar to the blue ones, but much smaller for similar rating, I guess they must be a lower voltage rating.
      Havent got any 270nf but have a 340 and 220 as they are going in parallel I guess the values wouldn't matter that much.
      Is it worth trying them?
        Assuming you mean 330nF, in parallel with 220nF that makes 550nF, compared to 540nF. Close enough; these types of capacitors have a 5% or 10% tolerance and both are within that range. Are they definitely in parallel? A single 560nF may be okay.
        • bbjunkie
          • Dec 2011
          • 301
          I had thought about a single cap of 540nf but wondered if they were in parallel to avoid a catastrophic failure if it died.
          Will try the 340nf and 220nf
          • bbjunkie
            • Dec 2011
            • 301
            Perfect! got a nice picture on the set now. Started up no problem with the caps and I managed to salvage just enough good 2SD965's from the first time I replaced them all.
            All I need to do on this one now is repair the plastic tab that operates the standby switch.
            Thanks guys for all the help, as usual.. this forum is awesome!
            Jim
              Jim
              Great, another mystery solved, another TV fixed !
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • stomanata
                Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
                by stomanata
                on my previous post with help from this forum i found short circuit GIF5CH60TS-X
                I replace it but again give me error for current over 16A.
                I measure again and found short circuit between #15 and #16 (Cin and GND).
                On PCB i remove R121 to check in which direction is short circuit. But this pin goed
                to big copper piece on back side.
                So i try to measure over every resistor and capacitor
                But i can`t find any short circuit,
                On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
                1. Through CSF (i don`t know...
                09-15-2024, 02:06 AM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
