42inch Touch Screen wont power on
  • epicfatigue
    • Dec 2011
    • 68
    Re: 42inch Touch Screen wont power on
    Chip looks like
    L 6 5 9 (and 2x symbols that look like a light bulb and a capital D)
    (84 inside a circle) 9 0 7 B 6 5 0
    • retiredcaps
      • Apr 2010
      • 9271
      Hmm, no luck with either part number.
      What about those 2 ICs on the heatsink just above the Powerview logo? What are the part numbers of those two?
      --- begin sig file ---
      --- end sig file ---
      • epicfatigue
        • Dec 2011
        • 68
        I thought they were Power mosphets?
        I am at work at the moment i can check when i come home be home in 2 hours.
        I did notice on the far left hand side one of those atached to the heatsink is showing some discoloration and no others are.
        • retiredcaps
          • Apr 2010
          • 9271
          They could be combination power mosfet and smps. I can't recall which monitor, but there was one case where the two functions were integrated into one chip.
          • retiredcaps
            • Apr 2010
            • 9271
            Chip looks like
            L 6 5 9
            May have spoke too soon about not finding the part number. Digikey has this "L6599A"
            https://cdn.badcaps-static.com/pdfs/...d758189067.pdf
            I'll need someone with more experience to confirm, but if it is correct part, then we are interested in measuring pin 12.
            Pin 12 is the vcc. It needs between 10 and 11.4 V DC to turn on. From page 32, it looks like that should come from a 10uF capacitor. That 10uF capacitor could be the one just below the big SMPS and just to the right of the Powerview logo?
            Tests
            1) See if pin 12 (vcc) is shorted to pin 10 (gnd). Any resistance reading less than 30 ohms suggests it is bad. If yes, I believe that indicates L659 is bad.
            2) Since you will have to do board acrobatics to get readings, find a piece of cardboard to rest the board on so you don't accidentally short out anything.
            3) Carefully measure the DC voltage across the 10uF startup cap. Note the voltage and if it is steady of fluctuating. Black probe on negative leg and red probe on positive leg of cap.
            4) Measure the DC voltage on pin 12. Be CAREFUL not to let the probe slip and short out the IC. Again, note the voltage and if it is steady of fluctuating. Use pin 10 for ground.
            • epicfatigue
              • Dec 2011
              • 68
              #26
              Okay Shall do, does the Dot represent PIN 1?
              Should i measure the capacitance of all the caps? or even the startup cap while we wait to confirm the part number? also what kind of voltage should i see comming off these caps?
              And also can i measure the Powermosphets while in circuit?
              And if so what is the correct way to test them? from memory they were a gate of some kind.
              Furthermore i removed the Panel from the touchscreen unit and it is a LG panel, should i record the number for use on here? or is there no need as LG panels are used in lots of tvs.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Generally, yes, but see datasheet to confirm pin numbering and orientation.
                You can measure the uF if you want, but you have to desolder them to get an accurate reading. Plus I know of no multimeter that can measure ESR which is more important.
                You want to see DC voltage from the startup cap.
                For the mosfets, I normally test for shorts. I measure pin 1-2, 1-3, and 2-3. Any reading under 30 Ohms "in circuit" suggests a possible short.
                • epicfatigue
                  • Dec 2011
                  • 68
                  #28
                  Awesome well i will measure the mosfets for shorts and check the DC voltage for the caps, gunna be fun powering up this baby and checking the voltages.
                  I have one question on polarized, variable and standard caps.
                  Stop me if i am wrong.
                  Polarized i just have to follow neg with positive -) |-+ (ie positibe on right neg on left ?
                  variable and standards i can do it either way ? or do i have to use a common ground and touch the opposite side of it.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    If you are measuring capacitance of the electrolytic caps, then black probe goes to negative (usually stripe on the sleeve) and red probe goes to positive.
                    If you are measuring DC voltage of electrolytic caps, it is the same. Namely, black probe goes to negative (usually stripe on the sleeve) and red probe goes to positive.
                    • epicfatigue
                      • Dec 2011
                      • 68
                      #30
                      Hey so the 4.7uf 50V cap located on Diagram as A recorded 23.7mv
                      Regon B all the caps recorded 0 V
                      Should i measure C and D voltage?
                      Whats my next step i feel as if i am making progress.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        If A is indeed the startup cap, that voltage is way too low.
                        As expected because the SMPS hasn't started.
                        C will be 165 V DC. We know it works because we get 5 V standby. D might be the startup cap for the 5 V SMPS, but I'm not sure. It wouldn't hurt to measure it.
                        Also, waiting for post #25 tests 1 and 4.
                        • epicfatigue
                          • Dec 2011
                          • 68
                          #32
                          C= 330v
                          D= 120mv
                          and fuck me i touched the powerinvertor with my hand lmfao that shit hurts.
                          i shall check #25 shortly as i have to feed my dauhter
                          • epicfatigue
                            • Dec 2011
                            • 68
                            #33
                            Voltage moved upwards and keeptclimbing i took it of at 85mv
                            it has massive resitance btw
                              Before you look for Vcc/start up problems, check the output diodes for shorts. I was chasing around a problem like that on a DVD player (Vcc measured very low, about 1-2V) and it turned out the shorted diode on the secondary was not allowing the supply to bootstrap and supply the "run" power. If Vcc is still giving issues and diodes are not shorted, check the zener (if present), resistor and cap... Good luck.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                C= 330v
                                330 V DC means PFC is working.
                                On the hot side, all the heatsinks are "hot".
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Good suggestion.
                                  • epicfatigue
                                    • Dec 2011
                                    • 68
                                    #37
                                    :O found a shorted diode should i look for anything leading to it or after it?
                                    or just go ahead and replace it and hope she works?
                                      I can barely see the diode you are referring to. How did you test it? Looks like that's on the primary side, as you still have standby power that is odd...
                                      • epicfatigue
                                        • Dec 2011
                                        • 68
                                        #39
                                        it allows current both ways, i used my diode checker on the meter.
                                        In terms of checking resistors is there a site or a map that tells me what the bands mean so i am able to cross referance?
                                        there is a resistor on the op side next to the chip that is red black black gold which reads 10ohms and i believe this is be a 20ohm resistor could this be the problelm? replace both the resitor and diode?
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          1) Color code.
                                          http://en.wikipedia.org/wiki/Electro...r_and_inductor
                                          2) I think tom66 means these output diodes (circled in red). They have a marking that looks like
                                          pin 1 is on the left, 2 in the middle, and 3 on the right. Set your multimeter to diode and test pins 1-2, 2-1 and then 2-3, 3-2.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • AJ847.63e
                                            HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
                                            by AJ847.63e
                                            Hi All,
                                            We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
                                            Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
                                            I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
                                            04-04-2024, 05:29 PM
                                          • hotgly
                                            Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
                                            by hotgly
                                            After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
                                            The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
                                            I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
                                            Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
                                            Serial number: 0F00S2Y22353BF
                                            Intel(R) ME Code Versions:
                                            BIOS Version 12.200.143
                                            MEI Driver...
                                            05-15-2024, 02:20 PM
                                          • Yehuda170
                                            ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                            by Yehuda170
                                            original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                            replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                            now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                            with original broken screen i can see in device manager touch screen in human interfaces
                                            but with the new screen it's not showing in device manager
                                            is it lenovo blocking it? is it driver missing?
                                            I²C is a headache
                                            07-14-2023, 01:29 AM
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
