42inch Touch Screen wont power on
  • epicfatigue
    • Dec 2011
    • 68
    #41
    Re: 42inch Touch Screen wont power on
    Originally posted by retiredcaps
    1) Color code.
    http://en.wikipedia.org/wiki/Electro...r_and_inductor
    2) I think tom66 means these output diodes (circled in red). They have a marking that looks like
    pin 1 is on the left, 2 in the middle, and 3 on the right. Set your multimeter to diode and test pins 1-2, 2-1 and then 2-3, 3-2.
    man i got alot to learn i thought they were mospets, okay so these work late gates dont they?
    What kind of results should i expect to see from each combination?
      Generally, for a dual package diode you expect to see:
      1-2 open
      2-1 ~0.2V
      2-3 ~0.2V
      3-2 open
      3-1 open
      1-3 open
      It depends on the type of diode (schottky, fast recovery, and if it's a dual package); I can't see the part #s.
      If any reading shows 0V, the diode is almost certainly bad.
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        Don't let the physical packaging fool you. It is best to go by the pcb designator and look at the component part number and find its datasheet.
        Also, it is a mosfet.
        metal–oxide–semiconductor field-effect transistor
        --- begin sig file ---
        --- end sig file ---
        • epicfatigue
          • Dec 2011
          • 68
          #44
          Awesome thanks everyone once again i feel as if i am learning a lot.
          I shall check all of this once i get home from work but i do have a question.
          These diodes i am checking are located next to the caps that do not have power on the cold side, however we seem to be not gaining the correct voltage to the caps further back on the hot side?
          Wouldn't this mean the problem is further back or are we working from one end to the other to see if anything has shorted further on from the initial problem?
          (just trying to work out how we work process of elimination)
          • epicfatigue
            • Dec 2011
            • 68
            #45
            They are labled D704 etc etc for all the ones listed.
            thye are 3pins
            1-2 = 0.162 v
            1-3 = 0v
            2-3 = 0.162 v
            However the big white risistor labled r100JSMT mpr -5W and marking on board r601 locaded near the big cap reads .4 ohms
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              thye are 3pins
              1-2 = 0.162 v
              1-3 = 0v
              2-3 = 0.162 v
              Retest. Look carefully at post #40 and #42 for the pin combinations.
              • epicfatigue
                • Dec 2011
                • 68
                #47
                All of them read this
                i started with red on pin one then reversed, should this be done the other way?
                1-2 .112V (made a click)
                2-1 .162V
                2-3 .162V
                3-2 111
                3-1 0v
                1-3 0v
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  2-1 .162V
                  2-3 .162V
                  3-2 111
                  3-1 0v
                  1-3 0v
                  Hmm, these readings suggest they are all bad. I would desolder one of these diodes and retest out of circuit. In-circuit readings are inconclusive since other components can be affecting the readings.
                    Post a picture of the diode, or read off the part number.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      2-1 .162V
                      2-3 .162V
                      3-2 111
                      3-1 0v
                      1-3 0v
                      And just to confirm, are you measuring the diodes with the diode test function with the power off and TV unplugged?
                      • epicfatigue
                        • Dec 2011
                        • 68
                        #51
                        yes thats correct
                        1-2 .195v red pin 1 black pin 2
                        2-1 0V black pin 1 red pin 2
                        2-3 0 red pin 2 black pin 3
                        3-2 .197 black pin 2 red pin 3
                        3-1 0 red pin3 black pin 1
                        1-3 0 red pin 1 black pin 3
                        ->|-|<- B1861 F15JC10
                        • epicfatigue
                          • Dec 2011
                          • 68
                          #52
                          The above is out of circut
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            yes thats correct
                            Is it 0V or 0L? There is a huge difference between the two.
                              yes thats correct
                              Thanks for the part number, and it's nice the manufacturer has included a marking of polarity. That indicates a diode drop should be between middle pin and each other pin, with the black terminal on the middle pin.
                              Let's try a test too - what reading to you get if you set your meter to diode test mode, but don't connect the probes to anything? In other words, an open circuit. I'm worried you might be confusing 0L or "1 ." for a zero.
                              edit: oops 1 minute too late!
                              • epicfatigue
                                • Dec 2011
                                • 68
                                #55
                                open .0L closed 0 volts ? is that right shouldnt it read the voltage of the battery?
                                and yes lol it is .0L i am reading sorry guys
                                so this means it is functioning correctly
                                  Yes, those readings indicate a functional diode. Now test the other diodes. No need to post more results unless you are unsure of the reading or if you are getting odd readings. We are looking for a diode which is not behaving properly.
                                  • epicfatigue
                                    • Dec 2011
                                    • 68
                                    #57
                                    boyah lots of desoldering !!!
                                    the white paste on these its this just thermal paste?
                                      In most cases, you do not need to desolder the diodes. Remove them and test out of circuit only if you get ambiguous readings.
                                      Yes, the white stuff is thermal paste. If you replace a diode, I recommend you add some more paste (any stuff will do, you can buy it off eBay.)
                                      • epicfatigue
                                        • Dec 2011
                                        • 68
                                        #59
                                        kool, and is it thermal paste on these? or do i need to go out and buy something special?
                                        Also is it possible this chip we were looking for is mounted on the small heatsink?
                                        As it is a 6 prong i will try and get the part number off it but it is labled as an IC
                                          The 6 pin chip might be a power supply controller; we can check it out later. For now, we'll focus on one thing at a time, the diodes for now.
                                          Yes, the white stuff is the thermal paste. If the paste isn't smudged, then you might not need some more paste, but I'd recommend it anyway. Here is something that will work: http://www.ebay.co.uk/itm/CPU-Therma...item3f10fcf53e
                                          Get two or three, as one of those tubes doesn't last long.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • AJ847.63e
                                            HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
                                            by AJ847.63e
                                            Hi All,
                                            We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
                                            Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
                                            I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
                                            04-04-2024, 05:29 PM
                                          • hotgly
                                            Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
                                            by hotgly
                                            After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
                                            The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
                                            I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
                                            Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
                                            Serial number: 0F00S2Y22353BF
                                            Intel(R) ME Code Versions:
                                            BIOS Version 12.200.143
                                            MEI Driver...
                                            05-15-2024, 02:20 PM
                                          • Yehuda170
                                            ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                            by Yehuda170
                                            original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                            replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                            now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                            with original broken screen i can see in device manager touch screen in human interfaces
                                            but with the new screen it's not showing in device manager
                                            is it lenovo blocking it? is it driver missing?
                                            I²C is a headache
                                            07-14-2023, 01:29 AM
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
