Philips 37PFL5322D/37 Chirping from psu
  • Mr Bill
    • Nov 2011
    • 648
    I'm trying to repair my cousins 37" lcd. I was told the tv just flat out shut off while watching it. We pulled the back cover and discovered the 3 capacitors were bad. The 3 in a row that are circled. 1 was swollen and the other 2 leaked. We replaced the 3 and one more thats also circled in the picture. The capacitors were replaced with Nichicon 1000uf 35V capacitors. All 4 that were replaced are all the same value. We plugged the tv in to verify and now we are getting a chirping noise from the power supply. The standby light is illuminated red and it changes to green when the power button is pressed. I'm having a hard time narrowing down exactly where its coming from but my guess is its in the neighborhood of the verical transformer. Does anyone have any sugggestions as to where to start checking. I do have a multimeter but thats it. If anyone does have any suggestions i'm probably going to need specifics on exactly what to do considering i'm a total NOOB in this area.
    Many thanks in advance
  • Mr Bill
    • Nov 2011
    • 648
    Re: Philips 37PFL5322D/37 Chirping from psu
    Here is an update. With the tv plugged in but powered off you can hear a very faint ticking. Turn the tv on and you get the chirping. I read in another post that the TEA1507P chip goes bad. I checked the pins and when i checked pin #4 you can hear the ticking alot louder. Its doing it on both chips.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      What were the old caps? capxon teapo? what series?
      What series nichicon caps did you use to replace them? Did you match the ripple and use low esr caps?
      Chirping may be the ripple not getting filter correctly and is reaching the smps controller causing it to excessively tick/chirp.
      Does the TV function normally or is it still dead?
      It could be a bad/loose windings on a transformer that you may be hearing, just a thought.
      • Mr Bill
        • Nov 2011
        • 648
        The original capacitors were CapXon GF series. The 4 i replaced are VZ(M) series i think. 105 degree celcius. The Tv is still dead. It wouldn't power on at all before the capacitor swap.
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          Here's your problem..
          VZ are general purpose, not low ESR, nor does the ripple and esr come anywhere near a GF spec capacitor .
          Rip them out and do it again.
          Replace them with this
          Panasonic FM
          http://search.digikey.com/us/en/prod...2405-ND/613766
          High ripple, low esr.
          3190mA 15 mOhms to be exact.
          GF were 2780mA 19 mOhms, VZ were 810mA doesn't list impedance.
          • Mr Bill
            • Nov 2011
            • 648
            I ordered the capacitors from digi-key. I'll post results when i get/install them.
            Thanks for the help
            • Mr Bill
              • Nov 2011
              • 648
              Well,
              we plugged the tv in for a brief moment to show a family member the chirping and discovered the big transformer (the one in the center of the pic in my first post), puffed a small amout of gray smoke on the first chirp. If you turned the set off and waited a minute then turned it back on it did it again. It came from the corner of the transformer. You can smell a burn smell from that area. So if the transfromer can be replaced is it worth replacing or should i start trolling ebay for a replacement power board. I have ordered the capacitors that mad suggested yesterday. The numbers on the transformer are:
              80TL37T911 HJ
              HJC-S6192
              HJC DV-130-1 0720Q
              The best i could find for a replacement transformer is part #996510003228
              Sears parts direct shows it in stock for $2.16
              Should i take the gamble? Any opinions?
              • PlainBill
                • Feb 2009
                • 7034
                Originally posted by Mr Bill
                Well,
                80TL37T911 HJ
                HJC-S6192
                HJC DV-130-1 0720Q
                If risking $2.16 represents a major risk, unsolder the transformer and check for any signs of problems - scorch marks, etc. Also check for any possible components mounted under the transformer. A shorted transformer is very rare, but considering the difference in cost, I'd buy the transformer at that price.
                PlainBill
                • Mr Bill
                  • Nov 2011
                  • 648
                  Bill,
                  is there a way to test the transformer with a multimeter after i desolder it from the board?
                  • Mr Bill
                    • Nov 2011
                    • 648
                    Does it looked cooked to you? And whats up with the solder puddles on the one side? Is that normal?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      It looks normal. If you are sure the puff of smoke was from the transformer, replace it.
                      PlainBill
                      • Mr Bill
                        • Nov 2011
                        • 648
                        Its FIXED!!
                        It wasn't the transformer. The puff of smoke was coming from the one diode directly next to the transformer. P6KE120A
                        I went to radio shack and got a diode. Installed it and the chirping is gone and i have a screen. I'm gonna now order the correct part from digi-key and that should seal the deal.
                        I would like to thank all that were involved in this ordeal
                        • RobPhotoPro
                          Learning Fast
                          • Jun 2011
                          • 34
                          I was just wondering, what the exact position of the faulty diode was (like D925 ...)
                          Congrats to your successful repair!
                          • M_Kempf
                            • Jul 2012
                            Im having this exact issue with the same tv. Is there anyway you can let me know the exact location of the diode you replaced? I would really appreciate your help. Thanks
                            • Mr Bill
                              • Nov 2011
                              • 648
                              ZD902 & ZD904
                              The 2 diodes directly next to the transformer
                                Check those 3 Diodes, remove them to test them out off the board.
                                The one Bill replaced is part of the snubber circuits.
                                • M_Kempf
                                  • Jul 2012
                                  Thanks for your help I will try to replace these are all three (3) diodes the same or are they diffrent?
                                    They are not all the same, look at the p/n as printed.
                                    The one Bill replaced:
                                    http://www.mouser.com/ProductDetail/...4Drj3a5ZKuw%3d
                                    • tedsunrise
                                      • Dec 2012
                                      • 4
                                      • usa
                                      Wow this board has been a lot of help. I also have the chirping issue and started a new post yesterday on this site in regards to it. So far i also replaced the 4 capacitors along with a ceramic capacitor located in the same area as the bad zener diodes by the transformer. I too had my board plugged in to show someone the noise when i noticed a puff of smoke from the ceramic capacitor.
                                      After doing diode tests i could not get a reading at location 6062. I have removed the diode and now I can't figure out how to match the diode to buy a new one. The numbers on it only bring up data sheets on google and i cannot figure out the chart. Radioshack is clueless and i'm a novice so everything is a learning process right now.
                                      Has anyone ever replaced the diode at location 6062? I'm hoping i can replace that today and recheck the zener diodes that everyone says to replace by the transformer. Does anyone know what i should be getting for readings on these diodes? As a last resort i was going to swap the transformer if it is cheap and easy to find.
                                      Have been scared to do voltage tests on the board because it gets so hot as soon as it is plugged in. I'm nervous i will do more damage keeping it plugged in while testing so i have only been performing resistance checks so far which i know won't get me far.
                                      I work on diesel engines and repairing tvs on the side has been my little hobby lately that i'm getting into. However by the end of the night i would like to crack open a beer and enjoy the picture on this 42mf521d/37!
                                      Also i apologize, i know these questions have been asked already and i'm doing my best to search the threads for info before asking. But this will be day 3 now and frustration is starting to set in!! I plan on going through some of Mr. Bills voltage tests with my DMM if I have to...
                                      • janisutx
                                        ZD902 & ZD904
                                        Thanks Mr. Bill. My TV is now working again thanks to you. My bad caps were replaced and my Philips TV stilled chirped until these two diodes were replaced too.
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • tester001
                                          PLP-60-48 Single Output LED Power Supply - "chirping" noise
                                          by tester001
                                          Dear Badcaps forum members,
                                          Hope that you are all well!
                                          I am a newbie on a mission to figure out the cause of the PSU making a "chirping" noise:
                                          Having searched for this symptom online I have found some indication that failed capacitors may be an issue. To help with the troubleshooting, I have tried to isolate the problem and disconnected the PSU from the rest of the device - the chirping remained.
                                          I have then found that the whole PSU (apart from a small add-on board) can be replaced, and there is even a datasheet for it: https://cdn.badc...
                                          12-06-2023, 06:39 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
