Prive 32" LCD TV Red Blinking Light
  • Solder Boy
    • Nov 2006
    • 178
    Hi this is a Prive 32" LCD TV.. similar to the Soyo. Original customer complaint is that it won't turn on.. you just get a red blinking light on the front panel.
    Customer already bought replacement power supply board, it didn't solve his problem. I checked the replacement PS board.. all the caps test fine ESR wise. Checked output voltage. The only thing I'm getting is 5VDC.. there is no 12VDC at all.
    Checked the caps in the power distribution board.. they all test OK.
    Decided to check all the caps on the logic/video board. The caps marked in black on the photo are bad.
    Any thoughts about the lack of 12VDC? Thanks!
    www.bcrelectronics.ca
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Prive 32" LCD TV Red Blinking Light
    Most LCD TVs only have a standby supply running (3.3 or 5 volts usually) until the unit is turned on. Apparently the main board is not telling the power board to turn on. That is why you don't have 12 volts.
    • Solder Boy
      • Nov 2006
      • 178
      Thanks for the info. Couldn't wait for any more feedback here so I ended up bringing the board to another technician where I live who has more experience than me.
      After a few tests.. he confirmed the board was faulty.. so I guess the customer is sending it back for RMA.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • pc_okay
        LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
        by pc_okay
        Hello friends,
        I have this laptop AMD Platform starting & not posting, fan spinning.
        When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
        If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
        I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
        CPU and his area heat, maybe the cpu is dead?
        10-21-2024, 10:23 AM
