Olevia 265-t12 - no place to turn but the Internet
Re: Olevia 265-t12 - no place to turn but the Internet
Thanks for that. I remeasured and got consistentcy from each Inverter set.
Inverter 1 - 25.1
Inverter 2 - 25.1
Inverter 3 - 25.1
Inverter 4 - 24.7
Inverter 5 - 24.7
Inverter 6 - 24.7
That should be the DC readings for power to the inverter boards. does that mean anything?Comment
The legend says 24V DC. 25.1 is a tad high, but your multimeter may not be very accurate since it is on the 200V DC scale. Under load, it might actually be closer to 24V DC as well.
For now, I would assume this is okay. If one read 13V DC, then I would say we have "smoking gun".--- begin sig file ---
--- end sig file ---Comment
The next step will be to get a part number for the inverter boards and try and find the pin-out of the connector going to the master. It's possible the main board is shutting down the inverters itself.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hi Tom I am not sure how to do that but I can get the part numbers. There are 4 different inverter boards. I will label each below the same way. Starting from the bottom left through clockwise.
Inverter 1 - RDENC2244TPZZ IM3818-2
Inverter 2 - RDENC2243TPZZ IM3818-1 (master - already replaced)
Inverter 3 - RDENC2244TPZZ IM3818-2
Inverter 4 - RDENC2246TPZZ IM3818-4
Inverter 5 - RDENC2245TPZZ IM3818-3 (slave)
Inverter 6 - RDENC2246TPZZ IM3818-4
So what next?Comment
Why does this TV have two power supplies?
If anything I would look at the Power-supplies as the problem if one has failed and not providing power to one of the 6 inverters, that would be enough to bring the set down.Comment
A few posts back I noted the output voltages for each red wire on each inverter. They were all consistent and within an acceptable range per retiredcaps.
I am at a loss at this point but it would appear the issue is inverter side? Any and all suggestions welcome. I have invested so much time in this I would hate to not be able to end up with a fixComment
I disconnected each inverter from the tube and attempted to power it on. I connected one tube and then one inverter (6 connections) and still get the 2 seconds to black. For what its worth i guess :/Comment
That's normal. the inverter contains protection circuitry which typically monitors the voltage across and the current through each CCFL. If either is out of spec, the inverter shuts down.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
This looks to be a really strange setup.
Is there any connection between the two power supplies,other than the AC source?
On the inverters do they all have there own controller for the inverter?
Where the inverters come together,is there a connection between them?Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
Could you post a clear and detailed shot of the connector which connects to one of the inverters in this image with the white wires?
Does that connector go the main board? If so, post a picture on the main board side, too.
Also, try removing the inverter with this connector and posting a picture of the bottom - if you're lucky, there will be a key to the pins on the bottom.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
From the Power supplies there are 3 power outputs to the each inverter per board, totalling 6. Then there is a red/black connection, which is assume is the AC source and there is a couple of connections to the AV input section.
The inverters appear to be controlled by the middle inverter in the series where the ccfl outputs are blue/white wire combination. I am posting a pic of one I replaced and is dismounted from the TV.
The big white wire clump is where the master and slave inverters are connected. I took several pictures, hoping one of them gives a clear shot to the markings and is what we are looking for. Let me know
Attached Filesif you find these attachements useful please consider making a small donation to the site
The big clump of white wires is what connects the slave and master inverters together. The small bunch of white wires on the pics i just posted are what look to connect to a control board of sorts. I took oa picture of the back and also another where you can see the wires go underneath the AV in/out section and under the control headed to the other inverter board.Could you post a clear and detailed shot of the connector which connects to one of the inverters in this image with the white wires?
I copied a pic offline of what the exposed control board looks like. I would have to remove the power supply and the metal covering to get to it on my panel. Hope that helps.Attached Filesif you find these attachements useful please consider making a small donation to the site
I've tagged a number of semiconductors in the attached picture.
1 thru 6 are 16 pin ICs. What are the part numbers (I suspect they may be identical)?
7 appears to be a power transistor or voltage regulator. What is it's part number?
8 is the one I am most interested in. It is most likely the inverter controller. What is it's part number?
PlainBillAttached Filesif you find these attachements useful please consider making a small donation to the site
OK, So I finally got back around to this project. I found the problem. One of the tubes is half dark. So there are a bunch of tubes and one is dark on the right side of the LCD panel. I know which one!
Now what do I do? Could it be that bulb since half of it appears to light up? I can post some pics later for reference.
Thanks for the assistance and patience everyone
I had already swapped the entire inverter and the problem persisted. The confusing thing for me is that the CCFL looks like on long horizontal tube and my mind tells me that if it were the tube the whole thing would be dark. But I dont know how it actually works.
I am pretty sure its not the transformer or the inverter board and I measured all output, fuses, etc. So it means the tube right?
If it is, where do you find one?Comment
As a follow up I was able to determine the panel info. It is a Sharp LK645D3LZ29. I measured the length of the CCFL bubs and without pulling it and getting it exact its about 58 inches long.
Hope that helpsComment
Hi zodono, sorry for the late response but yes I resolved the issue but have another problem. What I did was take the panel down to the tubes and when powering on I could see one of the CCFL was only illuminated halfway. This led me to isolate the transformer on the board that was faulty. I purchased a replacement board so I pulled a transformer from that and soldered onto the inverter in its place and it had been working well for up until recently.
The problem resurfaced and I did the same thing and found a new transformer is having a problem. So I proceeded with the same fix and in the process damaged a couple pads from the transformer. So I bought the same inverter board from ebay and now it just powers down after 2 seconds. So I think there is a fault with this one. I am exhausted with dealing with the set.
I think I am going to give up on this set and get what I can get from another adventurous home electrician.Comment
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
- Loading...
