Philips 42" plasma screens
  • arneson
    • Sep 2005
    • 1267
    News story tonight reports all large philips plasma sets are overheating with badcaps.
    They are so concerned about fire hazard they're sending techs to every one with replacement cap.
    I'm watching a 60" Philips right now, but it's not plasma, I never liked them.
    Jim
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Philips 42" plasma screens
    yes i saw that also
    http://news.com.com/Philips+to+fix+1...tml?tag=cd.top
    Dutch company Philips Electronics will make house calls to repair almost 12,000 flat-panel plasma TV sets in the United States because of risks that they will overheat, it said on Friday.
    The problem occurred in 42-inch and 50-inch sets. It is restricted to the United States, because the faulty capacitors involved are used only in the assembly lines for the U.S. market.
    hehe cheap versions for US market with crapcaps
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      kinda like samsung blue label crt's
      they must have known they were crap.they went into oem monitors but samsung branded ones often had hitachi or panasonic crt.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        they probably will be doing board swaps at peoples homes not recappings. 12.000 new boards + labour, nice financial smack in the face.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          apparently these smacks are not painful enough.
          how long has this badcaps thing been going on now?
          the beancounters dont care though.
          • gonzo0815
            • Feb 2006
            • 1600
            Yes, but the beancounters who is responsible for that will hopefuly be fired.
            • celiabrown
              Issue with Plasma Philips 37inch chassis FTL2.1
              by celiabrown
              Hello guys,
              My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
              Can someone has any symptom like this ?
              Thanks​
              05-09-2024, 10:56 PM
            • alro7779
              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
              by alro7779
              Hello, guys!
              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
              09-14-2025, 12:25 AM
            • diamon
              Issues with new Surface Pro 5 screens
              by diamon
              I have three Microsoft Surface Pro 5 model 1796, with all cracked screens.
              Have bought from Aliexpress three new screens, the part numbers from my and the seller are the same:
              Bad working China screen part number:
              Good working own screen part number
              Error I get with the bad working China screen:
              No error with the good working own screen:
              All the three China screens (all the same exact part numbers) produce the same error in Device manager. Have also performed a clean installation...
              06-25-2023, 01:41 PM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • double_DD
              Philips curling iron - is this a common AC cable?
              by double_DD
              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
              08-18-2025, 10:04 AM
