Panasonic TH-42PX80EA standby PS
  • blownelco
    • Apr 2008
    • 12
    I have a Panasonic with dead standby powersupply.
    The buffer elco C407 was bulged and the fuse F403 was blown.
    I replaced the fuse and capacitor. As capacitor i took a 33ùF instead of the 22ùF. Is this a problem?
    At power up the fuse was gone again and IC409 MIP3E30 blownup.
    I have bought a new one and installed.
    After connecting power (without powerswitch on) i have now about 235VDC
    Isn't that to low, i was expecting +/- 300V?
    (230V AC grid)
    Someone an idea what is wrong?
    thanks in advance
  • BobbyMJ
    Panasonic TC-P60S30 - no standby voltage
    by BobbyMJ
    Hi All,
    Wanting to learn some electronics repair skills.
    I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
    So far I have found a blown cap on the main power supply board.
    After replacing it there's still no standby power.
    Poked around and found a resistor on the PSUB power supply board that measures open.
    An online resistor calculator shows this is a 93k ohm resister.
    My questions:
    Is that correct, 93k ohms?
    Is it a fusible resistor?
    Lastly, how do I know what wattage?...
    05-14-2025, 06:42 PM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • Nevillet
    Panasonic SA-PM71SD Micro HiFi - not comming out of standby
    by Nevillet
    Hi All,
    I have the above mini HiFi that after powering displays the standby LED and when the power switch is pressed the relay momentarily clicks in then cuts out again.
    I've included an image of the power board schematic.
    There is 5.9V present on pin 4 of CN507 and when the standby button is pressed 2.6V momentarily appears on pin2 of the same connector.
    Any thoughts would be welcome.
    The service manual exceeds the Badcaps file size limit but it can be found here:...
    08-24-2023, 10:58 AM
  • Xrious
    Panasonic TH-55FX600 - No standby LED
    by Xrious
    Got a TH-55FX600 that is showing no signs of life.
    Outputs from the P board look good, but no 12V on the A board.
    Very similar to https://www.badcaps.net/forum/troubl...3e-identidy-ic but where Tibd has 3.3v on the EN pin I have nothing, no voltage at all.
    Looking at the diagram for the IC I can see the enable is W_OPCTRL9, but I can't find a source for this, can anyone help please?
    Stu
    05-02-2024, 08:56 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
