Panasonic SA-PM71SD Micro HiFi - not comming out of standby
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I have the above mini HiFi that after powering displays the standby LED and when the power switch is pressed the relay momentarily clicks in then cuts out again.
    I've included an image of the power board schematic.
    There is 5.9V present on pin 4 of CN507 and when the standby button is pressed 2.6V momentarily appears on pin2 of the same connector.
    Any thoughts would be welcome.
    The service manual exceeds the Badcaps file size limit but it can be found here:
    • 31291
    Re: Panasonic SA-PM71SD Micro HiFi - not comming out of standby
    the first thing to do is look for cracked solder joints on these stupid designs with boards at angles to each other
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      I agree it's a horrible design and they are painfull to work on. Saying that all the solder joints look OK and I've reflowed most on the power & amplifier boards but still no further forwards..
      • R_J
        • 9624
        There is likely a short somewhere off the S3 S4 line, my first guess would be a defective audio output module.
        • BobbyMJ
          Panasonic TC-P60S30 - no standby voltage
          by BobbyMJ
          Hi All,
          Wanting to learn some electronics repair skills.
          I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
          So far I have found a blown cap on the main power supply board.
          After replacing it there's still no standby power.
          Poked around and found a resistor on the PSUB power supply board that measures open.
          An online resistor calculator shows this is a 93k ohm resister.
          My questions:
          Is that correct, 93k ohms?
          Is it a fusible resistor?
          Lastly, how do I know what wattage?...
          05-14-2025, 06:42 PM
        • Xrious
          Panasonic TH-55FX600 - No standby LED
          by Xrious
          Got a TH-55FX600 that is showing no signs of life.
          Outputs from the P board look good, but no 12V on the A board.
          Very similar to https://www.badcaps.net/forum/troubl...3e-identidy-ic but where Tibd has 3.3v on the EN pin I have nothing, no voltage at all.
          Looking at the diagram for the IC I can see the enable is W_OPCTRL9, but I can't find a source for this, can anyone help please?
          Stu
          05-02-2024, 08:56 PM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • lcdcaps1
          Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
          by lcdcaps1
          Hi
          I have a Panasonic SAPM-31 mini hifi and the tape deck motor keeps spinning all the time
          If I just connect the ribbon cable to PCB That is connected to the motor, it spins continuously
          If I change the input it still spins
          I have put it all back together with all the belts in place and still
          I can play, forward and rewind but the motor never stops when I press stop
          This never used to happen so I am not sure if a transistor has failed or a diode
          I will really appreciate the help from this forum
          Thanks all
          04-11-2022, 01:53 PM
        • MUNASHE
          Panasonic TH-32A315M, standby red light, but won't power on
          by MUNASHE
          Hi everyone
          I have a Panasonic TH-32A315M, that won't power on but standby red light is present
          Pliz help
          10-13-2022, 07:11 AM
