Panasonic TH-55FX600 - No standby LED
  • Xrious
    • May 2024
    • 4
    • New Zealand
    Got a TH-55FX600 that is showing no signs of life.
    Outputs from the P board look good, but no 12V on the A board.
    Very similar to https://www.badcaps.net/forum/troubl...3e-identidy-ic but where Tibd has 3.3v on the EN pin I have nothing, no voltage at all.
    Looking at the diagram for the IC I can see the enable is W_OPCTRL9, but I can't find a source for this, can anyone help please?
    Stu
    Click image for larger version  Name:	image.png Views:	1 Size:	7.0 KB ID:	3264024
  • Xrious
    • May 2024
    • 4
    • New Zealand
    Typical, just after posting and re-reading for the 4th time I think I understand, this is a PWM signal from the main IC?
    So test by injecting 12V in to the bus and see if the rest of the TV is working or just replace the A board?
    Sorry, typing and thinking at the same time..
    Stu
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • dajoker
      Panasonic th-p50s10d - blinky red, SC board go boom
      by dajoker
      My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
      I chased my way through the PSU, and a board, with no results.
      Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
      I only have the right half of the picture.
      Left half is completely blank.
      now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
      all the other voltage rails...
      09-24-2024, 04:39 AM
