My tv will not come on. When plugged up word vizio glows orange, but when you press power it flickers white for a sec the goes dark. It makes no sound like it is trying to come on and the screen never comes on. No internal lights or anything. Not sure if it is the power supply or what. What do I need to check first? Any help would be greatly appreciated.
vixio vx42l hdtv10a
Tags: None
Re: vixio vx42l hdtv10a
well, I don't really see any visible caps that are bad. It all depends on if you want to get the tv back going quickly or if you want to try and fix as cheap as possible. I found a board on ebay for $65 which is pretty good. You could probably re-cap the whole board for less than 15 bucks but not sure that will help you. Check the obvious fuses on the board also if you haven't done so yet.
http://cgi.ebay.com/VIZIO-POWER-SUPP...item1c1e021df7Comment
the black 470uf 16v rubycon looks a little bulged to me too but it's hard to tell really. I thought there was several bulged in the first picture but looking again in the third pic, they really looked ok. I'm with you on the caps. If i was going to replace one, I would do all.Comment
If it were not for the "flicker" you mention I would think it to be a main board problem.My tv will not come on. When plugged up word vizio glows orange, but when you press power it flickers white for a sec the goes dark. It makes no sound like it is trying to come on and the screen never comes on. No internal lights or anything. Not sure if it is the power supply or what. What do I need to check first? Any help would be greatly appreciated.Comment
I just had a Nov 2007 VX42L sent my way. All four 470uf 35v caps on the inverted boards are toast, and they show signs of having been replaced before. I believe I have some Panasonic FM's around I'll use, but I wonder if someone might help me determine what the last tech considered valid replacements... the last repairperson installed Samwha LT series. They are stamped 105c, but I can't for the life of me find any specs on the LT series on the web?
Thank you.
PS - There is also some bulging on the largest filter on the main supply, a 16d x 25h Nichicon 470uf 100v. I know I haven't any 100v caps in my bin. Any replacement suggestions for it? Panasonic NHG?Last edited by spiff59; 08-14-2011, 01:37 PM.Comment
Joe, i would replace these 3 caps first and see what you get. also check it over for krappy solder while it is out.
if ng we will have to start checking voltages to attempt to isolate the issue. From what your symptoms are, sure sounds like a cap issue.
check this thread to see what examples of bad capacitors are. Generally, you will see the top "domed" or the borrom rubber will be popped out... in some cases the sides of the capacitor will be bulged too.
https://www.badcaps.net/forum/showthread.php?t=424
However please keep in mind that a capacitor CAN fail internally/electrically and not show external symptoms..
If there are caps on the other boards please check them over as well.Last edited by cadillacman; 08-15-2011, 06:25 PM.Comment
Wow...
One usually assumes the bad part you pull out will be the same value as what you'll put back in... My VZ42HL main supply board doesn't look like the pictures you all are posting here. Could someone please tell me the value of C241? It's one of the caps under the heat sink on the right side of the supply. It's the cap closest to the center white connector. I have a bulging Nichicon 470mfd 100v 85c in that hole and a solder flux mess around it's PCB connections.
It think someone substituted their own value...
Is C241 supposed to be a 1000uf 35v like the one directly behind it?
Thank you.Comment
I am working on the VO42LHDTV10A myself, it may use the same set of inverter boards as your, so inspect them also.
See pictures here:
http://s807.photobucket.com/albums/y...VO42LFHDTV10A/
The board should be modified if they are the same as my.Attached FilesNever stop learning
Four 4.7 Ohm resistor 1/4W through hole or SMD type
Two 33V TVS (or ZENER Diode)
Two Capacitors MLCC TYPE 100pF 50V.
The list of parts are on page 2.
You may be able to find modification kit on EBAY.Never stop learning
@spiff59 : Please post a clear pictures so we can try to help and start a new thread so It will not confuse people since this thread is not the same model as your TV, it will help reduce confusion. Thanks.Never stop learning
by kjchatmanwhen it's plugged in the PCH glows under the thermal camera and the battery charges. the coil PLG1 for +vccin_aux reads 1.8v09-09-2025, 08:04 PM
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by CapacitorialHello guys.
I recently got a TV that has the following problems:- Sometimes it has to be turned on and off a few times, to boot up. Sometimes it starts from the first try
- When it is running normally, the right side of the screen flickers. Sometimes it is just a square of transparent white maybe a 1/3 of the right half (top right)
- The flicker is also sometimes a square that is filled with lines
- I noticed that when the TV brightness is set to max, it flickers less. I think the Standard setting is the worst where it comes more frequent
- When it runs a few minutes it gets better,
by aaabddooDell Precision 3520 intel vga error when Run the programl vga intel driver The screen flickers need help pls
Sorry for the language -
by edugimenoHi there!
I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some... - Loading...
