panasonic th-42px60u power problem no light
  • Toasty
    • Jul 2007
    • 4171
    Re: panasonic th-42px60u power problem no light
    I cannot say definitively without the unit in front of me. A power surge can mean a lot of things and do a lot of damage.
    You are more than welcome to attempt the IC replacement. Do you have the tools, materials, and skills necessary? It's the 24 pin SOIC on the back of the board. ~$20 + s/h
    Panasonic Part Number: C2ABDB000108
    veritas odium parit
    • gmzombie
      • Sep 2009
      • 83
      where is the best place to find that. i checked mouser and digikey
      • PlainBill
        • Feb 2009
        • 7034
        Google the Panasonic part number. Sears says it has been replaced with C2ABDB000110. Google that number and you will find several sources.
        PlainBill
        • Toasty
          • Jul 2007
          • 4171
          Did some more digging.
          Before you go any further with ordering...
          Hook it all together and answer this question:
          Is there 5V at pin 10 of connector P25 when the TV is plugged into the AC line?
          veritas odium parit
          • gmzombie
            • Sep 2009
            • 83
            yes there is 5v dc on pin 10 in the p25 connector
            • Toasty
              • Jul 2007
              • 4171
              #26
              Good.
              Next:
              Is there 2.7V at pin 13 of connector P25 when the TV is plugged into the AC line?
              Report any voltage reading there.
              veritas odium parit
              • gmzombie
                • Sep 2009
                • 83
                #27
                no voltage there on pin 13
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  Could you post a well lit pic of the central back area taken on about a 45° angle from left to right? Be sure to include the P, PA, and the DT (the perforated silver box).
                  I want to verify something for the next step.
                  I'm looking for the DG connector.
                  I think it's on the board under the DT (box) and should have a white ribbon-style cable going into it.
                  veritas odium parit
                  • gmzombie
                    • Sep 2009
                    • 83
                    #29
                    ok here are some pics i have a few more im posting now...it wouldnt let me post them all?
                    • gmzombie
                      • Sep 2009
                      • 83
                      #30
                      2nd half hopefully these help
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        At this point in the testing, the P board is no longer suspect.
                        Unplug the TV.
                        At the end of the flat white cable under your hand in the 3rd picture in the first set of pics is the DG3 connection. I am not sure if there is a locking mechanism in place on that cable or connector. Some use a clip. Some use a pressure clamp. Be careful and don't pull on it until you look at it carefully.
                        Disconnect connector DG3.
                        Plug the TV in.
                        Do the relays click after the TV is plugged into the AC line?
                        veritas odium parit
                        • gmzombie
                          • Sep 2009
                          • 83
                          #32
                          yes they do click on for a few seconds
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            Unplug the TV.
                            Reconnect the DG3 connector.
                            See the attached photo.
                            Disconnect H51 from the H board (red outline).
                            That's the board with all the RCA and other types of input jacks on it for the set.
                            The connector is towards the bottom (as indicated), under the area of the panel where it is marked:
                            Component Video
                            Input
                            1 2
                            You'll have to remove that framework around and over it (one big piece outlined in green) to get to the connector.
                            Once it is disconnected, plug the set back in.
                            Do the relays click?
                            If not, the H board is defective.
                            If yes, more to check.
                            veritas odium parit
                            • gmzombie
                              • Sep 2009
                              • 83
                              #34
                              after unplugging the p51 connector it still clicks when it is plugged in.
                              • Toasty
                                • Jul 2007
                                • 4171
                                #35
                                H51, yes? Not P51.
                                DG3 is connected, yes?
                                If you plug H51 back in, do the relays stop clicking when plugging it in?
                                Check the cable between the H51 and the G51 connector. If it's okay, then the fault is in the G board (front terminal).
                                Looking at the schematic, try jumping the power switch.
                                Pin 7 of G1 connector to chassis ground. Does the set come on?
                                If not, try it with the K1 plug unplugged. (other end of cable from G1 connector)
                                veritas odium parit
                                • gmzombie
                                  • Sep 2009
                                  • 83
                                  #36
                                  sorry missed the part about plugging back in dg3. when h51 is unplugged but dg3 is plugged in no clicks. so since it didnt click after i plugged in the dg3 and disconnected the h51 the h board would be defective correct?
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Correct.
                                    Disconnect power.
                                    Look in the area of the H51 connector for tiny 1mm square black chips with markings on the board FL2606, FL2607 etc.
                                    Check those with the DMM on continuity test (lowest scale).
                                    They should show continuity left to right and top to bottom,
                                    but -NOT-
                                    left or right TO top or bottom.
                                    veritas odium parit
                                    • gmzombie
                                      • Sep 2009
                                      • 83
                                      #38
                                      correct i checked all of the fl's in the area of the h51 and there were some that were pointed vertical but most of them were pointed horizontal and all of them had continuity.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        Not what I'm looking for. They all should have continuity.
                                        Look at this as a pinout of one of them.
                                        ┌─3─┐
                                        1░░░2
                                        └─4─┘
                                        Is there continuity from 1 to 3 on any of them?
                                        All should have continuity from 1 to 2
                                        All should have continuity from 3 to 4
                                        None should have continuity from 1 to 3 or 4
                                        None should have continuity from 2 to 3 or 4
                                        veritas odium parit
                                        • gmzombie
                                          • Sep 2009
                                          • 83
                                          #40
                                          fl2603,2602,2604 all show about 76ohms. the rest show o/l that is for 1/3 and 1/4
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • multimesut
                                            Dell 2007FPB Yellow Light Problem
                                            by multimesut
                                            Hello friends,
                                            A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                            11-13-2024, 07:00 AM
                                          • hugocarmo
                                            Panasonic TX-24A1UN CRT Sound and Input problem.
                                            by hugocarmo
                                            Hi.
                                            I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                            It is imaculate inside, almost no dust or debris inside.
                                            The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                            So I started to look for a service manual, I found one, and started from the beginning.
                                            Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                            04-26-2025, 07:45 PM
                                          • Tom_x
                                            HP Omen15 dc0001nh keyboard light problem
                                            by Tom_x
                                            Hi
                                            I have this HP laptop, board: DA0G3DMBCE0 rev:E
                                            The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
                                            Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
                                            I know schematic doesn't exist for this board
                                            Someone know similar board, that use this rgb keyboard light controller?
                                            regards
                                            04-05-2023, 10:32 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
