insignia 32" ldvd32g-10a acid trippy osd+ inputs
  • cadillacman
    • Feb 2011
    • 524
    Man i got ripped on this one... traded a nice 42" plasma i just fixed for this supposdly perfect working unit and a bunch of other junkers..
    when i play a dvd in the onboard dvd player, the pic looks good. THe little box that says "dvd" momentairly in the upper left also looks good.
    However the osd and any inoput i use looks acid trippy- like a photo negative almost.
    Has anybody ran into this? google search shows alot of folks with the same prob. Hopefully i have a blown pico fuse somewhere or something else simple.. this is a bummer man.
  • PlainBill
    • Feb 2009
    • 7034
    Re: insignia 32" ldvd32g-10a acid trippy osd+ inputs
    Probably not a picofuse. But I would start looking at voltage regulators and caps. 'Acid trippy' sounds like a lot of ripple in a power supply rail.
    PlainBill
    • cadillacman
      • Feb 2011
      • 524
      PlainBill
      man i sure hope thats all it is. i will post pics as soon as i figure out the wifes new camera..
      • Village Electronics
        OldPro
        • 118
        That is a bad panel.
        • cadiman
          • Mar 2010
          • 397
          Did you say that the on board dvd player showed a good picture?
          • cadillacman
            • Feb 2011
            • 524
            exactly. WHen i use the onboard dvd player it looks perfect. so it aint the panel..
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              Try feeding this unit by way of different inputs. One input may be hosed for the moment.
              • cadillacman
                • Feb 2011
                • 524
                all the red green blue component inputs look like that. all the tv function osds look like that. vol display looks like that.
                onboard dvd looks good, cable input shows regular colored snow so id assume thats an ok input( i need to get a remote fort this damn thing- id like to try a factory reset just for gigs)
                  OldPro
                  • 118
                  Post a perrfect picture
                    OldPro
                    • 118
                    Even the OSD has distortion.
                    • cadillacman
                      • Feb 2011
                      • 524
                      give me about 1/2 hr and i will. getting readt to tear it apart now and will get a pic of it before i tear it apart..
                      • cadillacman
                        • Feb 2011
                        • 524
                        ok wtf.. man i promise you when i checked this yesterday at work i played dvds for about 6 hrs- screen looked great. the only distortion noted at that time was with the osd only.
                        now the video from the dvd player is also trippy. Un fing believeable.
                        Could be this tv was mostly fine untill i transported it home or something....
                        heres pics of the remaning screen that is still "happy"
                        weired stripes in the second pic are from the camera..
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          Whenever you do post a picture, post one of a good dvd picture. This set's problems are puzzling.
                          • Dgtech
                            E. Technician
                            • Apr 2009
                            • 1462
                            • Steeler
                            that pic is a clue however the dvd pic should be when the dvd's playing. That screen is just a two color screen. Hard to confirm the problem is still there or not.
                            • cadillacman
                              • Feb 2011
                              • 524
                              Its there now. Im sure you think im nuts but it was not there before.
                              i guess 6 hrs of watching movies at work isnt good enough for this pos. Im not bothering to take a dvd pic because it looks just like the damn other stuff now.(however intermittently ill get a brief glimpse of proper color)
                              • Dgtech
                                E. Technician
                                • Apr 2009
                                • 1462
                                • Steeler
                                Check all cables and ribbon cables. There is something loose it sounds like.
                                • cadillacman
                                  • Feb 2011
                                  • 524
                                  man i sure hope so. Heading downstairs to my arcade/electronics shop now( finally)
                                  wish me luck!
                                  • daimoku
                                    • Feb 2011
                                    • 85
                                    I'd be especially thorough with the LVDS cable. I know some Vizios suffered from LVDS cable defects that would cause a miscolored image (although not to the extent pictured).
                                    • cadillacman
                                      • Feb 2011
                                      • 524
                                      pulled and reseated every cbale twice.. no dice. I havs good clean 5vdc(5.2 actually) and good clean 12v. No ac ripple in either one as well.
                                      Looks like the mainboard got wet at some point, i have very odd white stuff on it.
                                      theres also a big chip on the mainboard (traces fronm the tcon cable lead here) with a heatsink on it.
                                      Its poorly installed formt eh factory so the heatsink just wobbles. I wonder if thos board is just effed.
                                        OldPro
                                        • 118
                                        You have a bad panel. All the wishing in the world won't make it a good panel.
                                        There is a remote possibility that the T-Con board is the cause or as you pointed out the LDVS cable (very unlikely for this symptom). The likely hood is the panel itself. I have seen this flaw many, many times.
                                        Don't forget, that there is a good deal of electronics mounted under the metal shield of the panel. That electronics is connected to the set via ribbon connections to the T-Con board.
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • valvashon
                                          Insignia NS-LCD19-09 (third and final post, hopefully!)
                                          by valvashon
                                          I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                          Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                          10-22-2025, 12:33 PM
                                        • valvashon
                                          Insignia NS-LCD19-09 no standby LED; (new problem)
                                          by valvashon
                                          Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                          Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                          Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                          08-30-2023, 10:41 AM
                                        • tbsmith
                                          Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                                          by tbsmith
                                          There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                                          08-11-2025, 06:15 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
