50” Panasonic Plasma TV TH-50PX80U
  • ecking767
    • Oct 2009
    • 492
    $70.00 lesson learn after buying a power supply
    For the last week I have been working on a 50” Panasonic Plasma TV, model TH-50PX80U.
    The problem was when you press the power button, the TV will turn on and you can hear clicking noises coming from the power supply. Then the screen lights up for about 3 to 5 seconds and then the power turn off. No picture was display in the 3 to 5 seconds. I have checked all voltages according to the service manual and which all was good. I also disconnected SS board and SU board to see what effect it will have on the power supply and still no change.
    Next I started to check the caps and checking for shorts on the power supply and all check well. Then I started checking caps and checking for shorts on the SS board and SU board I found none. So I assumed the power was bad.
    I did a visual inspection of the three data drive board C1, C2 and C3. Then I check the 5 volt supply pin of C3 board for a short and found nothing. I never unplug the power connector for the C3 board and didn’t attempt to power up the TV with no power to the C3 board. This is when I learn my $70.00 lesson
    I order another power supply from eBay and once it arrived I install it and guess what? I was still having the same problem. So now I finally decided to unplug the power cable coming from SS board to the C3 board and then the TV stay power on to my surprise! After that I started to focus on the C3 board. The C3 board has three ribbons connector to drive sections of the screen. Removing the C3 board and getting a closer look under a magnifier glass I notice 2 surface mount 6.8 ohm resistor dark in color near first ribbon of the plasma screen. I replace the two resistor and they burn out again upon retesting. So checking the schematic of the C3 board to see what these two 6.8 ohm resistor was doing. After checking the schematic I decided to leave off the two 6.8 ohm resistor and unplug that ribbon for that section of the screen. Again I was surprise the TV power up and I got a picture!
    This prompted me to look at the C3 board more closely especially the pin out of the ribbon connector that drives that section of the screen. So I check the ribbon pin label VDD and GND and found they were shorted. WOW!
    Now my question is(but I think I already know the answer) can this be repair?
    What should I do with a 50” plasma TV that only display about 90% of a picture?
    Scrap it? Sell it? Use as is?
  • f67bird
    Technician
    • Apr 2007
    • 57
    Re: 50” Panasonic Plasma TV TH-50PX80U
    Order the C3 board.
    There is a used one on ebay now for $6.99 total with shipping included.
    If the parts on the C3 board burn out again, the panel is most likely causing it to
    fail. If thats the case, I don't think I would trash it, I would either use it as a monitor...
    or maybe pull all of the boards and sell them on ebay along with the remote control.
    Learner
    • ecking767
      • Oct 2009
      • 492
      Originally posted by f67bird
      Order the C3 board.
      I guess I wasn't clear on what's at fault. The panel green ribbon that connect to the C3 board is shorted.The C3 board is working fine (see the first picture). The VDD and GND is shorted making the measurement on the green ribbon not connect to the C3 board.
      • f67bird
        Technician
        • Apr 2007
        • 57
        The panel is bad then.
        Either use it as a monitor or sell the boards...or buy another same model tv that is not working and fix it up with your boards.
        Learner
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
