Re: Vizio VX32L turns on with backlight, no video or sound
I'm stuck. I've read through the posts on this. I too have a Vizio VX32L with the backlight on, but no sound, no picture. I turned the TV off via remote control, and the white light stayed on, but the picture turned off. Since then, I can only power it on, and must unplug it to get it to power off. From the sound of it, the problem is U7 or U9 or U33. I replaced U7 and U9 and get the voltages below:
IC Top Mid Bottom
U7 3.3 1.8 0
U8 3.3 2.2 0.4
U33 5.0 3.35 2.1
U2 5.1 3.3 2.0
U4 5.1 3.3 2.1
the power supply is putting out 5, 12, and 24 volts on the appropriate leads.
I checked both fuses on the MB and they are good. I ordered a 1513 (U5) from digikey at the same time, but I have not replaced that (not sure how to test it), but am not even sure that is the problem...don't want to go there if I can avoid it.
The symptoms are still the same- backlight with no picture/sound.
Any thoughts?
Thank you gentlemen. Once again proves that this is one hell of resource. My 32l lives! U33 replaced, total cost $2.50.Leave a comment:
Ugghh tried a TCON board off ebay, now instead of a slow white glow screen backlight comes on but still no pic, then shuts off after a bit. I thought it was going to work when I didn't see the white screen but now Im not sure if it's another bad tcon board or something else...Leave a comment:
I fixed one of these sets that had following symptoms. Plug in and get orange vizio logo. Turn on power and logo turns white. Then, nothing works and set has to be unplugged. I found a bad SMD LDO 1117 at U8 or U9 or U33 or something like that on the mainboard. It's a low dropout voltage regulator that had failed. Seems there were about 5 or 6 of them on the board so it wasn't that hard to find. Once I replaced it the TV worked like new and still is almost 3 years later. It was well worth the 49 cent fix. ;-)Leave a comment:
Dont worry I wont junk it. My girls only wish that was my style. Come to my house and see the junk everywhere!
I will save it like I do everything. TV boards are so plentiful and cheap. I have boards from my optical lens grinding machines common in my industry used to control stepper drive machinery which have a very small market but sell as individual boards even used for more than most complete HDTV's
Thats what i really need to tackle!Leave a comment:
Put it up on Craigslist for $30 someone will take it and may fix it.Leave a comment:
Ok - If your giving up on it dont junk it either keep it for parts or offer it for parts there is a classified forum on here or freecycle it - someone might want it.Leave a comment:
Yes I got a reading of no resistance all around the base of the fuse holders of F1 And F2. I am still hoisting the white flag my good man. My first attempt at board repair certainly wont be trying to revive this poor Frankenstien!Leave a comment:
That is a shame anyway just as one last try how about seeing if the "repair"
is actually good. The joint may have become cold. Easy ohms test
across the ends of the OLD fuse not the solder blobs. Also if the rest of the repair involved changing caps based on what they did to the fuse they have probably used caps that are not suitable. If you can tell if they replaced any we will be able to tell you if they are likely to be any good.Leave a comment:
Hah! How cheap is a bloody fuse? That's a fire hazard there... ever seen a smoking SMT transistor, not pretty, but also damn flammable! So, who knows what else has been damaged by the incompetent idiot with the soldering iron.Leave a comment:
Thanks selldoor, killian, retired caps, tom and vince for the advice.
I finally located the fuses. she said it went bad once before and a local repair shop fixed it for $150. It worked for a couple of months then died again
Check out part of the fix- a fuse bypass on the F2. Nice work. I only took 1 year of high school electronics 35 years ago but old Mr. Stan Day never reccommended that method of repair. I will never forget bad boys rape our young girls......
I think I will end my short career as a board repairman here, anything past a blown fuse is beyond my patience and skill set. i will continue to use this forum to trouble shoot in which boards the problems lie and checking obvious problems like fuses and burned and bulging components.
Thanks again to all who tried to help me.Leave a comment:
SellDoor is correct there are several versions of that Regulator Package (how it looks) Some have 3 legs and some have only 2 legs soldered with the middle leg cut off. In that case usually the wide metal tab at the top takes the place of the middle leg. I found a datasheet for this Regulator (not sure it is the exact same). It should give you some idea about these and their different packages.
http://pdf1.alldatasheet.com/datashe...X1084-1.5.html
Also on your Fuses they should be small white surface mounted (soldered on each end) and be marked as F1 and/or F2. Often there is written on the board the Amps and the Voltage of the Fuse. You can check them with a Digital MultiMeter set on Ohms with a probe on each end the DMM should read no more than 0.1 ohms. If it reads more than that the Fuse is probably bad. Good news is that they are cheap as are most of the other components on the board. Find the Fuse or Fuses and report back the Amps and Volts you got.Leave a comment:
"I just want to be clear where we are going and make sure if we get there i am capable of completing the tasks"
OK we can explain things at whatever level is needed.
Obviously we cant do the soldering or testing but can give step by step instructions. Whilst the set will be connected to the mains and on, most of the measurements will be low voltage so as long as you are careful to stay away from the HIgh voltage (Hot) side of the board except when guided to do so, you will be ok. I guess it was just a saying but drink and fixing electronics tend not to go well together.
Is your soldering iron electric and what wattage is it? 40 is often best. If you have time practice - just on any old bits of wire or electrical item. Similarly with your meter - practice on different setting check battery/cells car battery fuses bulbs power adapters - anything. It all helps you to get used to holding the probes and looking at the meter.- When it comes to the board checking there are two good rules.
Measure resistance = Power OFF
Measure voltage = Power ON.
You can get some practice on this board just measure resistance of various components and at the same time learn the board descriptions and what they look like.
Getting to the component in question, it is not fried-it is not meant to have 3 legs connected. The centre leg is meant to be cut off short, so that is why I suspect as it is not burnt it will be ok.
Unfortunately many of the tests to try and find the fault on the board rely on voltages and signals it receives from the other boards so it has to be connected.
It would be great if you tried to fix this as there are a lot of reported problems with this set and at least in your case it seems certain a problem on this board. If we can fix it then it will be something to help others in the future.Leave a comment:
The board is not hooked up to the TV yet again. I just want to be clear where we are going and make sure if we get there i am capable of completing the tasks. i havent used a soldering iron since the 70's. So are exploring the possibility that that component is still good and some how the connecting wire just got fried? If so for me it would be easier to just repair the connection while the component is out of the TV. I am a little nervous about testing voltages on a live board. I will probably need a stiff drink to steady my hand and then thats not such a good idea as well obviously. I am just being frank here I'm not a technician, I learned that years ago. Thanks for your patience. And I appreciate your trying to help me.Leave a comment:
http://en.wikipedia.org/wiki/Electro...e_designationsLeave a comment:
What are the voltages on the pins of that device? Check with the black probe in a spare screw hole and the red probe on each pin in succession (except the chopped off one, include the tab/fat pin at the top.)Leave a comment:
Ok I fixed it. Here we get 110 to 115v at 60hz. no I didnt test it I am not really sure how to do that. I was assuming that it wasnt supposed to look like that. it was my impression most of these components were very low priced if one could find them.Leave a comment:
@woodyfl perhaps we could make relevant suggestions if you were to update your profile with at least your country and while your in there mains voltage
Have you tested it - doesnt look burnt or anythingLast edited by selldoor; 06-01-2012, 01:57 PM.Leave a comment:
I cant seem to find out what is the equivalent of the U10
CAC 1084 0721 NL regulator? I guess
Where can one purchase this? Thanks in advanceLeave a comment:
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
by Super360Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
- Loading...
