how do test if a PDP is good ?
  • pr0cess0r
    • Jan 2011
    • 110
    hello i got 2 42 inch vimax plasma TV on of them the power supply board whas cracked and i fixed all broken traces the other is powering on but no display can i do a selft test on the panel or what parts i can swap from the workinh unit to know if the panel itseft is good before i do anything else ?
  • PlainBill
    • Feb 2009
    • 7034
    Re: how do test if a PDP is good ?
    Twitter is a useful tool. It forces those with nothing useful to say to demonstrate that in 137 characters or less. We don't have that limitation here.
    I read your post three times before I finally figured out what you were trying to ask. An intelligent use of the shift key, and of punctuation would help considerably.
    You can swap any boards which have the same board number between sets. I'm not sure who made your TVs; most hits from Googling Vimax refer to a herbal 'male enhancement' product.
    PlainBill
    • pr0cess0r
      • Jan 2011
      • 110
      Sorry, i will re write my initial post.. The tv is all made by samsung apart from the i/o board.
      • PlainBill
        • Feb 2009
        • 7034
        Good to know. That is a common configuration.
        Notice that the power supply must be readjusted for the panel - voltages are on a label on the panel. When testing move the Y-sustain and Y-buffers as a unit from one panel to the other; a bad Y-buffer can blow the Y-sustain.
        PlainBill
        • pr0cess0r
          • Jan 2011
          • 110
          I got it working but the is a line in it the panel must be dead i swapped everything!
          • SluggerB
            Help with trying to fix phone that is not charging (Pics inside)
            by SluggerB
            I have two TCL A30 phones.
            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
            New Phone: Works fine, bought as a donor board to try and repair Old Phone
            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
            08-12-2024, 08:11 AM
          • chth96
            How Can I test PWM DM0365R?
            by chth96
            Hello
            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
            06-18-2025, 04:14 PM
          • khelane
            test active pfc power with lamp test
            by khelane
            Hello
            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
            Is there a way...
            06-03-2025, 01:00 AM
          • irepair559
            Ps4 1215a hdmi diode readings good everything good but no pic??
            by irepair559
            PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
            01-05-2023, 12:32 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
