Got a Westinghouse monitor with no power or no backlight after a recap?
  • hardwareguy
    • Jun 2006
    • 405
    If your Westinghouse LCD with a Delta DAC-19M005 PSU board still doesn't power up or powers up but doesn't have a backlight, check some SMD fuses on the back of the board.
    I've got one with two blown fuses, one for the backlight feed, the other to the main board. F101 and F200 are open circuit.
    Unfortunately the current ratings are unknown....F101 and F200 have a "W" on them while F100 has an "S". Is there a chart for these?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Got a Westinghouse monitor with no power or no backlight after a recap?
    http://forums.xbox-scene.com/index.php?showtopic=658938
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      These fuses are different than the link retiredcaps suggested.
      Search for Boums fuses.W=4a and S=2a
      Do not pay attention to the letter shown on the link
      SF-1206F400-2CT-ND i think this might be the 4a from digi-key
      • jetadm123
        • 2169
        Also, be sure to check the two AP40T03 mosfet transistors for shorts. If one checks bad, then replace both. These transistors shorting is one of the causes for the fuse blowing.
        • retiredcaps
          • Apr 2010
          • 9271
          Oops, my bad. I'll delete that link from my bookmarks.
          • hardwareguy
            • Jun 2006
            • 405
            I initially suspected those...and then had to look back even further when I saw no gate drive on the scope.
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Zilicon
              NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
              by Zilicon
              Greetings everyone.
              Please I need help with the above monitor.
              Below is the summary of what happened and what I have done:
              The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
              The backlight driver IC is 0b3350cp.
              I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
              11-07-2023, 09:12 AM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
            • Chiro
              DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
              by Chiro
              The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
              07-06-2025, 02:21 PM
            • tmhobadcap
              LG 24MP56HQ-P Monitor Backlight problem?
              by tmhobadcap
              I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
              Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
              I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
              10-13-2021, 01:52 PM
