Got a Westinghouse monitor with no power or no backlight after a recap?
  • hardwareguy
    • Jun 2006
    • 405
    If your Westinghouse LCD with a Delta DAC-19M005 PSU board still doesn't power up or powers up but doesn't have a backlight, check some SMD fuses on the back of the board.
    I've got one with two blown fuses, one for the backlight feed, the other to the main board. F101 and F200 are open circuit.
    Unfortunately the current ratings are unknown....F101 and F200 have a "W" on them while F100 has an "S". Is there a chart for these?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Got a Westinghouse monitor with no power or no backlight after a recap?
    http://forums.xbox-scene.com/index.php?showtopic=658938
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      These fuses are different than the link retiredcaps suggested.
      Search for Boums fuses.W=4a and S=2a
      Do not pay attention to the letter shown on the link
      SF-1206F400-2CT-ND i think this might be the 4a from digi-key
      • jetadm123
        • 2169
        Also, be sure to check the two AP40T03 mosfet transistors for shorts. If one checks bad, then replace both. These transistors shorting is one of the causes for the fuse blowing.
        • retiredcaps
          • Apr 2010
          • 9271
          Oops, my bad. I'll delete that link from my bookmarks.
          • hardwareguy
            • Jun 2006
            • 405
            I initially suspected those...and then had to look back even further when I saw no gate drive on the scope.
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Zilicon
              NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
              by Zilicon
              Greetings everyone.
              Please I need help with the above monitor.
              Below is the summary of what happened and what I have done:
              The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
              The backlight driver IC is 0b3350cp.
              I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
              11-07-2023, 09:12 AM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • alro7779
              Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
              by alro7779
              Hello, guys!
              I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
              Alex....
              10-03-2025, 05:49 PM
