visio vx37l with black screen no sound
  • bobbyg
    • Jan 2011
    • 4
    I'm new to this forum and hope I can get some help in solving this problem.
    Heres where I'm at. Several weeks ago while watching this 2.5 year old visio hdtv, the screen went black and sound quit, and lost all controls. Had to unplug to turn off. After plugging it back in and power on, with remote, the visio light goes from orange to white, then back to orange. I pulled the set appart and tested the power supply voltages. I had no 24vdc, an found a tiny resistor blown. Their were also no visible bad caps or discolorations on it or any other board. So Being an impulsive guy, I immediately ordered a new power supply. I quickly installed it and excitedly turned it on. Well, the orange light came on. I pushed the power on button and the orange light turned white, but still no light or sound. Then i started checking voltages again. Heres what I have found so far.
    Main Board 3637-0112-0150
    f1---12vdc
    f2--- 5vdc
    u33--3.29vdc
    u2---3.29vdc
    u3---0vdc
    u4---3.29vdc
    u7---1.08vdc
    u8---3.3vdc
    u9---1.51vdc
    u10--2.59vdc
    New Power supply 24vdc,12vdc,5vdc
    Note: Does u3,u7,u9 and u10 have a problem with the lower voltages, if so what should they be. Is there something else I should check or am I wasting my time and money. Bobbyg
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: visio vx37l with black screen no sound
    f1---12vdc
    f2--- 5vdc
    u33--3.29vdc
    u2---3.29vdc
    u3---0vdc
    u4---3.29vdc
    u7---1.08vdc
    u8---3.3vdc
    u9---1.51vdc
    u10--2.59vdc
    Sounds like the main processing board.
    But, is it a LCD or a Plasma TV?
    Maybe a short circuit caused the resistor to burn out on your old power supply.
    -Ben
    Muh-soggy-knee
    • bobbyg
      • Jan 2011
      • 4
      Sorry about that, Its an lcd vx37lhdtv10a Bob
      • bobbyg
        • Jan 2011
        • 4
        Ben,
        I understand the inverter board needs 24vdc and a back light on signal tcontrol signal to turn on the back lights, I have the 24vdc at the inverter fuse, how do determine if I have the back light on signal using a digital voltmeter? I'd like to rule out the inverter if I can, before I get a main board.
        • BarrelRoll
          • Jan 2011
          • 34
          I have the same set with the same problem. Logo is orange, power up it goes white with the backlight coming on. Nothing on screen and can't turn it off.
          Power supply is putting out all the correct voltages, the backlight fires up but then I can't turn the TV off and nothing comes on the display. Also the optical audio output does not light up the laser diode.
          Checked F1 and F2 and both are OK. Getting 5 volts at the 7805T. It would not be unusual to see a 1.0 to 1.5 volt level for the ARM CPU core, but I suspect that the voltages that are near 3.3v, but not quite are a problem, and the 0 volt probe you have.
          This is apparently a pretty common problem and I'd rather not spend ~$100 on a replacement mainboard if it's a bad cap or failed solid state relay or something like that. None of my caps are showing any signs of damage either, though I think they are all Taicon. It's like the set can't get out of standby to actually boot and turn on anything but the backlight. It seems to be a fairly common problem but nobody has turned up what the problem is yet.
          • PlainBill
            • Feb 2009
            • 7034
            You'd get more help if you had posted this in the proper section. It belongs in the 'Electronics Theory and Troubleshooting'; 'Troubleshooting TVs and Video Sources' area. I suggest asking a mod to move it.
            PlainBill
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              PlainBill
              Been busy with college, missed this. Shame on me, the FAQ janitor!
              thread moved.
              (a lot of bad backlighted vizios lately... vizio?)
              sigpic
              (Insert witty quote here)
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • Rozp
                70LE660U dark cloud or black screen with sound.
                by Rozp
                Hello Everyone,
                This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                08-29-2023, 05:25 PM
              • Mgiffune
                by Mgiffune
                I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                I ordered a supposedly β€˜new' Tcon board this time, and
                06-09-2024, 10:28 AM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Audeze
                Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                by Audeze
                I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                Does...
                10-06-2024, 08:54 PM
