Phillips 50pf9639A
  • iggy2526
    • May 2010
    Phillips 50pf9639A
    this Phillips 50PF9630A dont start
  • epod
    • Dec 2010
    • 12
    Re: Phillips 50pf9639A
    what do you mean it wont start
    • De3rcr
      • Apr 2010
      • 94
      I don't think you will get much help with a "dont start " discription of the problem. Post pics of the boards and a more detailed discription of your problem.
      • cadiman
        • Mar 2010
        • 397
        Don`t start working on it. drag it to the curb. I would start with that.
        If you must attempt a repair I would start with the power supply.
          Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
          Brand: Philips
          MPN: 55POS900255
          GTIN: 8718863012352​...
          11-05-2024, 02:45 PM
        • learnmore
          Service manual req Phillips 75PUS6754/12
          by learnmore
          Hello Community,
          Would welcome any help on getting a service manaula for the above model (Phillips 75PUS6754/12) TV or anything similar.
          Picture intermittently works fine for a day or a minuite then goes off, but backlights appear to remain on.
          I thinking troubleshooting TV or using a tape method on the panel but would like some guidance on tracing the signals accurately rather than a trail and error.
          Thanks in advance,
          LM
          11-13-2023, 04:58 AM
        • playit
          ccfl lcd laptop repair help, pics attached
          by playit
          this lcd first started showing green lines horizontal ,with flickrs then one day stopped showing rest of the screen , now it just like in the pic , i can see mouse at top,also the icons at right end of screen , i also tried to look around the cable wires ,adn loosened it ,but its the same result . i tried the flex test , the monitor changes to white ,and different colours, but dint show the actual picture , external monitor vga connection is good, so please guide me what next to do . please verify the pics, thank you ....
          03-15-2023, 05:08 AM
        • Bloopeta
          Phillips 58PUS7805/12 No Picture
          by Bloopeta
          Phillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
          From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
          When one is unplugged, I get half sceen, clear picture.
          With other unplugged, get half screen but with thin horizontal lines
          Any ideas? Or is it likely a bad panel?...
          03-10-2023, 02:08 PM
        • SluggerB
          Help with trying to fix phone that is not charging (Pics inside)
          by SluggerB
          I have two TCL A30 phones.
          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
          New Phone: Works fine, bought as a donor board to try and repair Old Phone
          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
          08-12-2024, 08:11 AM
