Re: Vizio VW42LFHDTV10...Brother Mikes TV...Cap repair a no go
The test with the 6 new caps on the mainboard shows NOTHING has changed.
So to repeat the situation and readings...
Set double clicks when plugged in, amber light is on, 165V at main cap, and only 5VDC to mainboard, no other supplys...it then will not kick up by any other means except pressing SW1 and wait about 10 seconds, and it clicks up to white, then main cap is 400VDC, there is then 24 volts and 1.4v to master inverter, and 24v to slave inverter, and there is then 12v, 5v, and 1.4v to mainboard.
No blue diode for ccfl , no backlights or flash at all, no image or sound. Set will not turn off by SW1 but only if plugged pulled , and it will not return to 400vdc level by replugging.
What would you suggest next ?
