Toshiba 37" inverter board failure
  • whatusername
    • Dec 2013
    • 456
    Re: Toshiba 37" inverter board failure
    he does not know he said he bought the tv in a lot but is 100% sure it worked cuz the tv only had a cracked screen and was on and had video when he pulled the boards and bagged them..
    • whatusername
      • Dec 2013
      • 456
      so I take it there's no chance that the inverter board is pulling down the voltage?
        No, because your old power supply board is able to put out the 24V for the inverter to run and gives you the backlights. You should be able to put your old board back in and get the same condition as before, backlights on but no pictures shown on the screen due to no 12vlcd.
        • whatusername
          • Dec 2013
          • 456
          true that makes sense.. when I get home from work tonight I'll put the old boy back in and make sure I still get back lights
          • whatusername
            • Dec 2013
            • 456
            so bud i was testing the new broken board using the old one for reading comparison and came across this big thing on the top left i think it could be a bridge rectifier not sure but it failed a test againt my old one.. it shows open on one of the leggs its q660 u got info on it? str-z2589
            ok its a power ic http://www.datasheetdir.com/STR-Z2589+SMPS-Controller
              You mean Q860,which is for the 12V and 24V power supply. That means there is problem with that section on your new board that it cannot supply the voltage to run the inverter board.
              Also it is where that mod is done to it on your replacement board.
              • whatusername
                • Dec 2013
                • 456
                yes from the test i have done between the boards on my old board there are a couple leggs that show a 1 in diode mode when i touch them and on this board those same legs show a value in diode mode so that would mean its faulty correct?
                • whatusername
                  • Dec 2013
                  • 456
                  because i am thinking of swapping str-z2589 from the old board to the new board.. and the resistor was added to a zenor diode mine original reads 793 in diode and where they put the resistor on that same zener it reads 693 so its 100 difference in the 2
                    Yes, I think we already know that the new board has problem when it cannot power up the inverter board. I wonder what that MOD with that resistor is about.
                    You may want to check the resistance of that 12VLCD to see what the reading will show compare to your old board. I hope you can return this defective board.
                    • whatusername
                      • Dec 2013
                      • 456
                      not sure what u mean check the resistance of the 12vlcd but yes i can return the board but them im stuck in the same place where we left off because i couldnt find what u asked for.. i was hoping to make a good board out of the 2 if i could do that then it would be worth the 55 i paid for it (to me at least) becaus all that tedious trouble shooting that got me stuck will be bypassed
                      • whatusername
                        • Dec 2013
                        • 456
                        my only option themn would be to ship the old board to you have u fix it and pay u for the repair and send this one back to the seller.. Would that be an option u would consider?
                          We know that we have shorted circuit in the 12VLCD section that we were trying figure out what went wrong in that section, we removed the shorted cap and the Zener diode but we cannot get the 24V at the input put of the buck converter IC.
                          If you are going to remove the good known IC Q860 and install it into your new board, you need to find out what that added on resistor is for. Is it fusible resistor or what it is used for?
                          I do no have much spare time to dedicate in fixing your old board, I would like to try but time is the problem.
                          • whatusername
                            • Dec 2013
                            • 456
                            ok i understand the time restraint .. and as stated the added on resistor is soldered on to the zener diode my guess is the diode blew and instead of replacing it he soldered a resistor to it to make it work.. he also has replaced a few smd caps u can see in the pic i uploaded yesterday... so i think the resistor was an i dont have the part fix..
                              Yes, but that mod does not work because the 24V is not working with the load (inverter board). I think he thought he fixed the board with that mod but did not install it into the TV or even put on dummy load to find out if it can handle the load. You will need to put that section back to the original condition as your original board, and who knows what else is not properly done to this board.
                              • whatusername
                                • Dec 2013
                                • 456
                                ok so i swapped the power ic and ur right i should swap the zener diode too
                                • whatusername
                                  • Dec 2013
                                  • 456
                                  ok well i replaced them both and tested the board alone and now have 5v standby
                                  so gonna install in tv and see what happens.. wish me luck
                                  • whatusername
                                    • Dec 2013
                                    • 456
                                    ok so the only difference is now i get 5v when before i didnt... i still get a declining 2.5v on 12v and 24v is only 1.8v
                                      Well it is worst than you original board. May be you can transfer the parts for the 12VLCD section of the new board to the old board.
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        yea im gonna have to undo everything i just did.. i will do it tomorrow and what parts would u recommend i swap over?
                                          The IC, the cap and the Zener diode as shown in the 12vlcd diagram, I hope you can locate that IC on the board which we could not find last time.
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
