LG 55UH7650-UA needs a capacitor!
  • x_orange90_x
    • May 2015
    • 727
    I got an LG 55UH7650-UA that I could hear popping when I plugged it in. After opening it up I found a ceramic disc cap that's completely obliterated. I can't find a schematic for the board, and the cap is obviously unreadable. I read someone else on another forum ask about the same cap, or so it appeared. Their board however looked different and the cap was in a different location on the board.
    I have junk power boards with a bunch of these style caps, but most are 1kV or 250v. How can I be sure I get the right rated cap if I don't have a schematic?
    The board in my TV is EAY64210702.
  • alfatv
    • Sep 2020
    • 353
    Re: LG 55UH7650-UA needs a capacitor!
    1kV is voltage rating, most likely you need that type, but you also need capacitance, somewhere around 220-470pF. Take a look at blue cap in 1st picture, very likely it's the same type. Also check both transistors mounted on a heatsink.
    • x_orange90_x
      • May 2015
      • 727
      Ok that's a good idea. I'll look at that other one. Are you suspecting damage to those transistors as well?
      • alfatv
        • Sep 2020
        • 353
        Yes. The damage would be short circuit between 2nd and 3rd pin.
        • lotas
          • Jan 2016
          • 4749
          • Russia
          Transistors don’t always burn out, sometimes you’re lucky and only the capacitor and fuse burn out. Check the resistance of these mosfets and the two diodes on the back of the board.
          • x_orange90_x
            • May 2015
            • 727
            I replaced the bad cap last night but still no power. The surrounding components may be bad. Still need to get my multimeter to check those.
            • slybunda
              • Feb 2012
              • 139
              zoomed in on those 2 pink resistors, one looks like its gone out of shape.
              • x_orange90_x
                • May 2015
                • 727
                Yes I seen that. It's lumpy and rough looking.
                • EazyBone
                  • Jun 2023
                  • 1353
                  • United states
                  What is the purpose of that paste on the blue cap? I know certain size caps need to be glued down but those blue caps don't fit that. Why is it actually there? Anyone know
                  • x_orange90_x
                    • May 2015
                    • 727
                    I'm thinking it's either there to protect them from heat coming off surrounding components, or to pull heat off of themselves? I'm trying to decipher the color codes of those resistors but the middle stripe is confusing me. It clearly looks silver but according to the chart it can't be silver, but grey instead. Also I don't know what that little black component is under the goop by my finger. There is no writing on it 😒
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      The black thing is a inductor.
                      • lotas
                        • Jan 2016
                        • 4749
                        • Russia
                        I I'm trying to decipher the color codes of those resistors but the middle stripe is confusing me. It clearly looks silver but according to the chart it can't be silver, but grey instead. 😒
                        These resistors are wirewound, low resistance 0.15 Ohm 1%.
                        • lotas
                          • Jan 2016
                          • 4749
                          • Russia
                          Have you checked the fuses?
                          • x_orange90_x
                            • May 2015
                            • 727
                            No I haven't. They don't appear burned or anything, but they are the white ones, not glass, so the inside may be a different story. I imagine they are ok because the bad cap was still sparking before I replaced it. If the fuses were blown the power wouldn't make it over to that cap, right? Btw there are two fuses on this board.
                            • lotas
                              • Jan 2016
                              • 4749
                              • Russia
                              If it sparked, it means it was shorted, then this fuse could have burned out; you can simply check it with a multimeter.
                              • x_orange90_x
                                • May 2015
                                • 727
                                I'll check that tonight. That would be great if that was the issue! So the fuse is further in the circuit than the cap that shorted?
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  It's being used as insulation.
                                  • x_orange90_x
                                    • May 2015
                                    • 727
                                    Unfortunately I can't find my multimeter to test anything ��
                                    What is more likey to be bad? The fuse, or the transistors? Or maybe all of them? I have some donor boards that may have the right transistors.
                                    • lotas
                                      • Jan 2016
                                      • 4749
                                      • Russia
                                      How do you repair equipment (TVs) without a multimeter?
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        😆 I haven't needed to use it until recently. Last time I used it was just before my basement flooded, so I think it was misplaced after the cleanup. I have an idea now where it may be though.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
