Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
  • kca
    • Feb 2016
    • 529
    Hello all ~
    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
    No picture. No sound.
    I tested all the voltages coming out of the power supply and also their counterpart voltages at the connector on the main board (both the original main board and the newly purchased one).
    I found something unusual, I think. The line marked SDA was initially reading only 0.6. I think this needs to be st or around 3.3v. The SCL line, adjacent to the SDA, seems to read properly at 3.6 or 3.7.
    Then, when I retested all the same voltages the next morning the SDA line was then reading 2.6v instead of 0.6. Here are my questions:
    1. Does a SDA voltage usually read 3.3 volts?
    2. If so, does the 2.6 voltage account for the 5 blink error and the no picture / no sound / reboot cycling described above? In other words, is there a minimum voltage (perhaps 3.0 or higher) that this SDA line needs to operate at in order to not cause an issue?
    3. What would account for the jump from 0.6v to 2.6v on the SDA line when I changed nothing overnight?
    Thanks for any and all help you can provide. I’ll add some pics soon, but the only issue I can directly determine at this juncture are the mysterious and likely insufficient voltage on this particular SDA line.
    ~ kca
  • Diah
    • Feb 2013
    • 6343
    Re: Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
    known fault at F serial . fault Caps at Cold area power boards.... start from there.... but put back your original HIDMI fault MB in place
    • kca
      • Feb 2016
      • 529
      UPDATE:
      Checked all the caps on the power supply board. All OK. At that point, I measured the voltages at the exit connector of the power supply board with the end of the cable at the main board fully disconnected.
      Now, the 2,6v reading on the SDA line is reading 3.6. So, with no main board in play, the power supply board seems to be fully functioning. All 13 voltages read at or slightly above the levels indicated on the printed circuit board itself. Note: The primary voltages are supposed to be 13v, according to the print, but all six of those are all reading at 14.2. I think this is a non-issue, but please correct me if I’m wrong.
      What appears to be happening is that when the data is transferred to and from the main board it immediately drops the voltage to this lower, 2.6v level.
      Questions:
      1. Is this drop on the SDA line normal, or is this the manifestation of a fault on the main board? Strange that the SCL (clock) remains steady at 3.6 or 3.7 in all circumstances.
      It’s beginning to feel like the 2.6v might be a normal drop as the data only needs that much to execute its tranfer(s)?
      2. Can the T-Con board be involved in this issue?
      3. I still get the 5 red blink / cycling pattern as previously described when the main board is disconnected from the power supply board. What does this indicate, if anything?
      Next, I’m going to put the original main board back in and check all the voltages again. Will report when that’s accomplished.
      Thanks in advance ~
      ~ kca
        • 12081
        • U.S.
        Checked all the caps, in what manner did you check them?
        • kca
          • Feb 2016
          • 529
          Thanks for the help so far. Nomoresonys ~ Here’s an update that will likely reorient us:
          Put the original main board back in. Whereas this read 0.6v on SDA at the main board’s connector a few days ago, it now is reading a full 3.5v on both the main board connector side as well as the power supply board connector side. It all appears to be correct. Did not see that coming. Note: a few days ago, when I measured, I only did so at the main board connector.
          I also plugged and unplugged the T-con board in every logical combination just now to no avail. The 5 red blink / cycling pattern happens in every scenario I’ve tested.
          Is there any explanation why ine non-working main board would now read correctly on the SDA at 3.5v when it clearly only read 0.6 before at the main board connector?
          And, how could one main board read 2.6v while another reads 3.5v SDA? Especially given that both produce the same fault code and cycling pattern. One could say the newly purchased main board is defective, but that doesn’t explain the original main board’s continued issue-producing troubles.
          Is there a way I can reset the tv at the circuit boards themselves and would that help?
          Quick addendum: All of the aforementioned voltages are perfectly stable. They do not fluctuate in any manner. So, the 3.5 sustained and consistent volts at both the (original) main board AND at the PS side seems to be proof that all the caps and other components on the Power Supply board itself are working properly. Is that the case?
          ~ kca
          • Diah
            • Feb 2013
            • 6343
            caps fault..... even testing outside will not help... because the legs of caps inside could have issue.. change them you will be fine.
              • 12081
              • U.S.
              That is a very good question, wonder if you might have had a bad connection and unplugging and re-plugging connectors made it better.
                • 12081
                • U.S.
                I trust you Diah, that's good advice, tv is about 10 years old, who knows what quality of caps they used.
                  • 12081
                  • U.S.
                  A good rule of cap changing is use the same uf and go up a little in voltage, lots of times they use less than adequate caps to cut production costs to the bone and of course make it non-functional just outside of warranty.
                  • kca
                    • Feb 2016
                    • 529
                    In the process of a few more voltage tests, but I have a couple cap related questions:
                    1. I’m counting 11 electrolytic caps, 3 ceramic caps and 2 square box type caps on the cold side of the board. Are you recommending that I have to replace them all because there’s no definitive way to assess them?
                    2. Are we saying that the faulty cap or caps are preventing the LED lights of the panel to initiate and that’s why there is no picture on the screen and no discernible backlights when the cable is disconnected from the main board?
                    That would make sense to me, as there is some (albeit somewhat inconsistent) proof that all the PS voltages running from the PS to the main board are in fact present.
                    3. If the problem rests in the failure of the LED panel lights to fire up, how do I determine that it’s not these LED lights themselves that’s at the root of the problem?
                    I would prefer not to perform a comprehensive cap replacement on the PS if the problem might be foundationally elsewhere.
                    I’m going to add a few pics to help you visualize how this particular set is designed. The last two in the photo set are stock photos of the front and back of the power supply board (BN44-00656A). The others are of the tv itself.
                    I’ll also upload one of the entire back of the television and some close-ups of the main board in my next post. Thanks, in advance, for addressing the above questions.
                    ~ kca
                    • kca
                      • Feb 2016
                      • 529
                      A few more images:
                      ~ kca
                      Looks like the photos got uploaded in upside-down fashion again. I don't know why that happens sometimes. But you get the general idea of the layout.
                        • 12081
                        • U.S.
                        Try heating just the round electrolytic caps with a hairdryer for a couple minutes, then try the tv, see if there's any difference, DON'T wait til it cools off to try it, it's just a test that can let a marginal/bad cap work for a very brief time if it isn't too far gone. Many times it's the electrolytic caps that puke out first, so those are the ones to check or replace first.
                        • EazyBone
                          • Jun 2023
                          • 1303
                          • United states
                          Generally with Samsungs at least last 6 years roughly, when you disconnect the main board from the PSU and leave the LEDs connected and plug it in, the LEDs should light up. If not, it's the power board or LEDs. This may be older and not the case but you can try. Otherwise LED tester works, maybe someone can tell you how to test the ribbon style as I don't know.
                          I would try to test the LEDs first.
                          Hey Sony, maybe you seen my other thread but applied here also.
                          If the cap is 450v 10 uf, what voltage would you up the cap to?
                          • kca
                            • Feb 2016
                            • 529
                            Alright.
                            Good idea with the hair dryer heat. I’ll try that next. Hopefully that triggers something and narrows down the bad cap search.
                            There are no backlights. Those have been out for about a week now. When the original main board was in place (and the only problem was that the 4 HDMI ports were not functioning) then yes ~~~ I was able to disconnect the cable to that main board and get the backlights to illuminate the entire screen. I’m not sure why the backlights ceased to function.
                            Thanks guys.
                            • lotas
                              • Jan 2016
                              • 4458
                              • Russia
                              The problem you have, as always, is in the xxF8000 series in the motherboard.
                                • 12081
                                • U.S.
                                I think with the bigger voltage caps like the 450 it's probably pretty safe to stay with the same voltage but if you put a 500 in there it would be ok too.
                                  • 12081
                                  • U.S.
                                  Can you elaborate, which part of the mb?
                                  • lotas
                                    • Jan 2016
                                    • 4458
                                    • Russia
                                    EMMC, micom power (3.3v), if 4 hdmi ports do not work, then something probably slipped (lightning, hot plug) at the input of any hdmi, the processor could be damaged.
                                      • 12081
                                      • U.S.
                                      Ok thanks, it seemed like from your post, that this series has a known weakness/issue with the mainboard.
                                      • kca
                                        • Feb 2016
                                        • 529
                                        Yes, I figure the processor is damaged on that original main board. Reflowing it had no effect. I tried it twice, actually, about 5 days apart from one another. Baked the board in the oven at 385 degrees for 10 minutes each time. That method has worked about 75% of the time over the years whenever the HDMI ports are the only thing defective on a set.
                                        At that point the screen still lit up and I watched tv via the coax cable for a couple days until the picture quality drove me crazy. That’s why I finally decided that the HDMI ports would likely never work again and it was time to purchase a new main board and hope it worked.
                                        The led panel lights seemed to go out shortly after the 2nd reflow attempt. Not immediately, as I recall, but within an hour or so. No popping sound or anything of the like. Just stopped working altogether when I turned the set back on at that particular juncture.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
