Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
  • nomoresonys
    • 12306
    • U.S.
    #41
    Re: Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
    Oh shit, my bad, I think I got 2 of his videos mixed up there.
    • kca
      • Feb 2016
      • 548
      Here are the voltages in detail on the primary connector:
      First, the odds
      1 (LD) = 3.6 (note, this pin does not have a wire leading to the main board: it is empty)
      3 (GND)= 0.0
      5 (B13v) = 14.7
      7 (B13v) = 14.7
      9 (SDA) = 1.0 (note, it only read 0.5 the 2nd time I measured it just now)
      11 (SCL) = 3.7
      13 (GND) = 0.0
      15 (B13v) = 14.7
      17 (B13v) = 14.7
      19 (VAMP) = 14.7
      21 (VAMP) = 14.7
      23 (GND) = 0.0
      25. (B5v) = 6.1
      27 (B5v) = 6.1
      Now, the evens:
      2 (SD) = 3.7 (note, this pin does not have a wire leading to the main board: it is empty)
      4! (CONTACT) = 3.7
      6 (VAMP) = 14.9
      8 (STT) = 3.7
      10 (DATA) = 3.7
      12 (UHR) = 3.7
      14 (EN0) = 3.7
      16. (VSYNC_) = 3.7
      18 (B13v) = 14.6
      20 (BLUONOFF) = 5.5
      22 (GND) = 0.0
      24. (GND) = 0.0
      26 (A5v) = 6.0
      28. (PWRONOFF) = 3.5
      They all look to be in order to me except for the SDA. Please inform if I am not correct on this.
      lotias ~ I’m pretty sure this is not a plasma tv set or a plasma PS board in any way. You could be right, but everything I’ve ever read indicates that it is an LED television.
      It is sometimes listed as an LED LCD Series (LCD Panel) as you’ll find in this article:
      https://www.bhphotovideo.com/c/produ...1080p_led.html
      From that article:
      Features
      The Samsung 60" 8000 Full HD Smart 3D LED TV features a 2D/3D LCD panel with 1920 x 1080p Full HD resolution, Ultra-Slim LED backlighting and a very high Clear Motion Rate of 1200 that promotes sharp detail and contrast - even when watching sports and action movies.
      • nomoresonys
        • 12306
        • U.S.
        #43
        No backlight, awe c'mon next you'll be saying that oled's don't have a backlight.
        • nomoresonys
          • 12306
          • U.S.
          #44
          I think they are in order too, you have all the proper voltages, makes me suspect the backlights, the thing is if they are bad they won't come on.
          • nomoresonys
            • 12306
            • U.S.
            #45
            I know plasmas don't have a led backlight, I have a bad memory but it isn't that fucking bad.
            • nomoresonys
              • 12306
              • U.S.
              #46
              I'm done here, fixing tvs sometimes requires putting in the labor, good luck.
              • kca
                • Feb 2016
                • 548
                Yes, that’s the Catch-22.
                But if I knew how to attempt a jump of the backlights on then at least that stands a chance of them coming on and eliminating them from the problematic picture.
                It’s always frustrating when the fault design allows for the 5 red blinks to be EITHER the PS supply OR the backlights. That, at least, appears to be the case with the fault codes.
                Would be so much easier if the backlights not working would produce their own, singular fault code on the red front LED light. Like, say ……. 6 red blinks. Would save mountains of time.
                Seems like I would need to try to jump the BLUONOFF pin to another pin, but not sure which one, exactly, would at least attempt to ignite the backlights. Any ideas / experiences would help.
                • nomoresonys
                  • 12306
                  • U.S.
                  #48
                  I don't know about this exact model but some will have voltage at the backlight connector pins with that connector unhooked, maybe if you have 0 voltage on those pins then it could be no voltage coming from the power supply, it's hard to believe nobody here has dealt with an f8000 before.
                  • nomoresonys
                    • 12306
                    • U.S.
                    #49
                    You can test the backlights without them being connected, this guy is using 9 volt batteries, I've done it, before getting a tester: https://www.youtube.com/watch?v=rNqRZ2qaDJY
                    • kca
                      • Feb 2016
                      • 548
                      Thanks, nomore ~
                      That’s very interesting. Never saw that video before. I’m going to gather up some 9v batteries and give that a try. I’ve got the 100 Ohm resistor but may need to purchase the finer point probes.
                      But this seems like the easiest, most seamless way to test these various LED strips without the risk of damaging other boards or components.
                      Much thanks !!
                      I’m grateful you persevered. . I will too.
                      ~ kca
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • jchang
                        Samsung UN70NU6900F no picture and no sound
                        by jchang
                        Hi all
                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                        Symptom:
                        No picture no sound.
                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                        No sound at all.
                        What I tried:
                        1. I tried unplugging the left or right ribbon...
                        01-09-2023, 06:28 PM
                      • Dodgethis
                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                        by Dodgethis
                        Hello all,
                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                        09-11-2024, 07:39 AM
