HISENSE H55B7500UK has backlight no picture
  • Diah
    • Feb 2013
    • 6399
    Re: HISENSE H55B7500UK has backlight no picture
    Originally posted by lotas
    I understand that it is necessary to break one channel, but why hang the two ends of the lamp on one wire, what is it?
    hahahaha.... i just saw his uploaded photo ...LOL he is doing wrong LOL
    OP: you should cut the wire and connect the 2 end to lamps wire...LOL
    • lotas
      • Jan 2016
      • 4668
      • Russia
      #42
      That’s what I wrote about!
      • snowangel27
        • Aug 2023
        • 45
        #43
        how silly i am, sorry diah, i will do it in the right way
        • snowangel27
          • Aug 2023
          • 45
          #44
          Done and still has nothing on the screen(see video).
          I already did exactly u said.
          https://drive.google.com/file/d/133t...w?usp=drivesdk
          • snowangel27
            • Aug 2023
            • 45
            #45
            And i checked t con board 1 one more times.
            It has 12v on fuse, vcc 1.8v, frc 1.2v.
            So maybe the problem is on the panel, right?
            • Diah
              • Feb 2013
              • 6399
              could be... but when you did the lamp test... how was the Red LED indicator behavior? did it change to blue
              • Diah
                • Feb 2013
                • 6399
                from yours Photo.... N1 & N2 are connected together.... i wrote before if they connected together the lamp test you need to do it to P1 & P2
                • snowangel27
                  • Aug 2023
                  • 45
                  #48
                  I did the test with p1 & p2 too but nothing changed.
                  • Diah
                    • Feb 2013
                    • 6399
                    invest to replace t-con
                    • snowangel27
                      • Aug 2023
                      • 45
                      #50
                      Can you explain more detail why the t con board need to be replaced, please?
                      • Diah
                        • Feb 2013
                        • 6399
                        because you did test it before ... disconnect the lvds cable from it,,, and feed the fuse of it 12v from power boards,,, but you don't have any sign or color pattern on panel
                        you can do the test again .. for several time... hope it come out and give sign
                        • EazyBone
                          • Jun 2023
                          • 1350
                          • United states
                          #52
                          Snow, diah has had me do this test on this type of TV also. Jump the 12v to fuse on tcon with lvds disc from MB . When I did it though I had to wait like 10-14 seconds before anything showed. ALSO I hooked up a backlight tester (assuming your backlights turn on during this test you won't have to) if lights don't turn on you better hit screen with a flashlight during test. My screen cycled green/red/colors BUT I had no backlight so I had to light it up. This info may or may not help but gl
                          • snowangel27
                            • Aug 2023
                            • 45
                            #53
                            Ok i will do the test again and wait a little bit longer. Maybe the screen will show color patterns ^^
                            • snowangel27
                              • Aug 2023
                              • 45
                              #54
                              I already jumped 12v to the fuse on the t con board and wait for a minute but still got nothing@@
                              • Diah
                                • Feb 2013
                                • 6399
                                do it again with half screen each time...by disconnect the ribbon , LVDS must be disconnected... if same result then i suggest as my Post #49
                                • nomoresonys
                                  • 12206
                                  • U.S.
                                  #56
                                  Saw some tcons on ebay UK for 20 pounds, probably try matching up the numbers on the white barcode, also seems like these guys claim they will price match: https://www.tvparts.co.uk/lcd-tv-spa...7500uk-a190421
                                  • nomoresonys
                                    • 12206
                                    • U.S.
                                    #57
                                    https://www.ebay.co.uk/sch/i.html?_f...acat=0&_sop=15
                                    • nomoresonys
                                      • 12206
                                      • U.S.
                                      #58
                                      I just took a quick look, so if you get one make sure it's compatible.
                                      • snowangel27
                                        • Aug 2023
                                        • 45
                                        #59
                                        Yes i tried disconnecting one by one but it s helpless.
                                        I already took another t con board from a cracked screen hisense tv to replace mine but the screen s still has nothing and the led light keep flashing 6 times.
                                        • snowangel27
                                          • Aug 2023
                                          • 45
                                          #60
                                          I m having 1 more cracked screen hisense tv(diffirent model but uses the same t con board). I tried to replace the t con board but nothing changed.
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • petersor
                                            Hisense 58R6E3 Backlight/No Picture Repaired
                                            by petersor
                                            Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
                                            06-07-2024, 04:16 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
