Vizio e65-f0 oddity
  • EazyBone
    • Jun 2023
    • 1328
    • United states
    Vizio e65-f0 oddity
    So I turn TV on. TV has no backlight but has picture. I considered LEDs, either way some oddity and I pulled it down to the LEDs and all LEDs light up and aren't dead. So I have it down to LEDs and plugged in and can hit power button (no panel connected) and I get these voltages
    connector CN201
    pin 1 (18vsb1) = 18v
    2 (18vsb1) = 18v
    3 (18vsb2) = 18v
    4 (18vsb2) = 18v
    5 (GND)
    6 (GND)
    7 (GND)
    8 (GND)
    9 (ps on/off) = 3.3
    10 (bl on/off) = 3.3
    11 (NC)
    12 (NC)
    CN301
    1 (vsync) = .017
    2 (hsync) = 3.3
    3 (mosi) 0
    4 (sclk) .057
    5 (miso).036
    6 (cs) 3.3
    7 (GND)
    8 (fault) = .044 and fluctuating to .8and drops immediately. Every 1 sec
    9 (5v sw) = 4.975
    10 (GND)
    CN601
    1 (v out) = 36v
    2 (vout) = 36v
    3 (vout) = 36v
    4 (nc)
    5 (nc)
    6 (nc)
    7 (led 1) = 5v
    8 (led 2) = 5v
    9 (led 3) = 5v
    10 (led 4) = 5v
    11 (led 5) = 5v
    12 (led 6) = 5v
    13 (nc)
    CN602
    1 (v out) = 36v
    2 (vout) = 36v
    3 (vout) = 36v
    4 (nc)
    5 (led 7) = 5v
    6 (led 8) = 5v
    9 (led 9) = 5v
    7 (led 10) = 5v
    8 (led 11) = 5v
    9 (led 12) = 5v
    Is the fault fluctuating telling us something? I'm using ground as negative for LED voltages, maybe that's wrong. But backlights will NOT turn on.
    I need help backlights need to turn on. Any experience with this?
    • 12184
    • U.S.
    Re: Vizio e65-f0 oddity
    Carefully measure the capacitors sitting sideways, a probe on each leg, what do you get it in standby and when powered on.
    • EazyBone
      • Jun 2023
      • 1328
      • United states
      I did, they read 389v both ways, for some reason I can't get the BL voltage to stay at 36 steady anymore
      So I noticed when I disconnect the main board, the one with fault from PB, fault goes to 3.3 and stays steady. When I plug it back in, that's when it goes from nothing, tries to jump up to 3.3 (I assume) and just drops back down. It keeps repeating this cycle continuously.
      Anyone know what this fault thing is? Maybe connected to this all?
      • EazyBone
        • Jun 2023
        • 1328
        • United states
        I can only assume something odd is coming from the main board telling it not to turn on or something. Thoughts?
        • EazyBone
          • Jun 2023
          • 1328
          • United states
          All c76,75,78,77 caps read short.
          Would reflow or whatever on main chip handle this you think?
          • diif
            • Feb 2014
            • 6978
            • England
            Short or low resistance ?
            • EazyBone
              • Jun 2023
              • 1328
              • United states
              000.1 or 000.2 all sides of each of them are short to ground also. I'm not expert here maybe that's how it's supposed to be
              • EazyBone
                • Jun 2023
                • 1328
                • United states
                Does anyone know what this fault thing is? Seems to be potential to the issue? Since it keeps fluctuating
                I've tried disconnecting the main board with this pin, and the power board keeps it at 3.3v along with cs
                I then pulled just that wire out the harness on pb side and plugged harness back in and it's fluctuating again. Something is sending a signal to it from MB I assume
                • EazyBone
                  • Jun 2023
                  • 1328
                  • United states
                  No one likes vizios eh lol
                    • 12184
                    • U.S.
                    Well where does that one faulty wire lead to on the mainboard, can you trace it and see what component/s it leads to/thru.
                    • EazyBone
                      • Jun 2023
                      • 1328
                      • United states
                      You ask the tough questions lol. I don't know yet lol I'll look and try take pictures. Do those short caps indicate something maybe?
                      Also Sony, you have 10,000 posts since 2013. That's 3 posts a day, off topic are you a TV repair person or what do you do. I'm a stay at home dad that is just fixing/selling and saving all cash for investment properties. Something to do since I can't go anywhere really
                        • 12184
                        • U.S.
                        Repair or trying to repair all things electronic or mechanical has been a long time hobby for me, not a career, good thing too because I'm too slow to fix things to make much money from it. Specially since prices plunged, I spend about an hour or so per day on it, should prolly switch to music, music is fun, a lot of times this is not.
                        • EazyBone
                          • Jun 2023
                          • 1328
                          • United states
                          Coo coo, ya I love fixing anything no matter what it is. I started with a OLED addition and telling wife I'm buying OLED for every room, bought first OLED for $50 broken. Fixed and started from there. Decided people giving away free "black tvs" and I flip them. I'm probably around 30 fixed so far. Probably 6-10 helped from here. I'm having fun. This Vizio is pissing me off though. Main board or PSU is what I see and I'm thinking main. I'd like to be a little more sure tho. Lights definitely work. Still need problem to find though
                            • 12184
                            • U.S.
                            On those caps reading short, how are you measuring, if you have your neg. probe on ground prolly only one side should show continuity/test as short.
                              • 12184
                              • U.S.
                              Lots of times when several read short it can be the ic closest to it that's the problem.
                              • EazyBone
                                • Jun 2023
                                • 1328
                                • United states
                                I measured one side neg one side red. Then I stuck new on a ground screw hole and measure each side. All 4 caps read grounded on both sides
                                  • 12184
                                  • U.S.
                                  Sure seems like a short.
                                  • EazyBone
                                    • Jun 2023
                                    • 1328
                                    • United states
                                    I'll have to bust out my short killer, never got it to help yet. We will see soon!
                                    The thing is though, I turn TV on and I get a picture. So I'm skeptical lol, but no BL won't turn on
                                      • 12184
                                      • U.S.
                                      Ok, no backlights then, take the cable CN201 off from powerboard to mainboard on powerboard side and measure those connector
                                      pins again on the powerboard.
                                      • EazyBone
                                        • Jun 2023
                                        • 1328
                                        • United states
                                        Tried that, they all become 3.3v lower. So 14.7, 14.7, none for bl on or PSON. I did check that, all voltages look normal. I'll still look through this motherboard here tonight.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • Iain P
                                          Vizio E65-F0 really dead
                                          by Iain P
                                          Hi everybody!
                                          I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                                          So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                                          I decided to check the voltages coming off the power supply they are as follows:
                                          connector CN201
                                          pin 1 (18vsb1)...
                                          02-23-2023, 11:32 AM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
