Hisense H6750G stumped on this
  • Diah
    • Feb 2013
    • 6499
    Re: Hisense H6750G stumped on this
    2 possibilities
    1- you may have one or more short LED BL
    2- Main Boards issue / firmware could be
    explaining
    Step down circuit .. PSU at STB standby status generate via line 12 V 7.8-10 V..... the step down on MB generate 3.3V to let the MB start script SPI Flash working and sending this 3.3V back to PSU to turn it on.... PSU will go high... mean the 7.8-10 V will be 12 V.
    but if PSU register over load at LED BL will report or some design it will handle the issue self and turn off the BL.
    but the IC you remarked it become hot on MB,, its belong to T.con 12 V. rail t delivered to T-CON from MB via LVDS
    as you said no change... keep the LVDS disconnected from MB side.... make wire jumper from 12V PSU socket direct to T-CON fuse... then turn on... see if the screen under tourch light generate color pattern... to be sure we have t_CON and panel are fine.... .... you can use too yours led testers to light on one group only of BL to see if screen work with out issue.
    other wise i will go to take screen apart and check LED if all lit on.... if yes then screen test if yes too nothings more only working on MB or replace it
    • EazyBone
      • Jun 2023
      • 1361
      • United states
      That does seem very hot for a voltage regulator, check those little caps right by it, are any shorted, also what do you get measured in ohms?
      None shorted ,
      C33/34 26.1 ohm
      C32/29 38 Kohm
      • EazyBone
        • Jun 2023
        • 1361
        • United states
        Here's tcon, I normally seen fuses lol can someone point out where the fuse is? I don't see one at all
        • Diah
          • Feb 2013
          • 6499
          on the right side the black on with T written on it as called on print F1
          • EazyBone
            • Jun 2023
            • 1361
            • United states
            Lol I did this and it worked lol. Saw red and green and bunch of colors. Well I need practice pulling apart a TV for the 1 millionth time lol so yea.
            I hate ripping these apart lol
            • Diah
              • Feb 2013
              • 6499
              good.... then follow one by one
              1- check the lvds cable between MB and T-con from both side if the contact pins didn't broken or short if okay....
              then
              2- take screen apart carefully to check with urs eyes if led bl all turn on not there shorted or off
              if okay...
              3- replace MB or work on it
              • EazyBone
                • Jun 2023
                • 1361
                • United states
                #27
                then
                if okay...
                I took this 75 inch screen off alone lol... And the friggin LEDs are fine. Scared to try and put the screen back on. Biggest one I've messed with now. Wish me luck. At least we are down to the last things lol. Mother friggin board.
                Any suggestions what I should be checking for? Obviously continuity but I've not been successful at fixing a MB yet. I've heated one with the main chip up and put it back in and had picture for a moment but that was it. Okay back together
                • Diah
                  • Feb 2013
                  • 6499
                  MB fixing are levels depend on the fault,,,,, for me personalty at any level i do determine the fault on it... if it goes to HW... my way to replace it,, but you can try... if yours eyes still in good young range lol
                  • EazyBone
                    • Jun 2023
                    • 1361
                    • United states
                    #29
                    Here's MB pic, I can't find anything wrong here. No shorts that I find. Is there some area I should look at? They don't have this MB online anywhere. Crazy
                    • Diah
                      • Feb 2013
                      • 6499
                      you need to check
                      1- LVDS connected.... check if T-CON fuse F1 have 12V from both side... if no V.
                      then disconnect the wifi / BT module from MB and check again. if still no V
                      you need to check the Regulator you said before its go hot read the V on all pins Ref to chassis
                      i think you have Service port on the side between USB port and HDMI , if this service port need to capture the log at start up the tV
                      also from ypurs post the 18V rail it read 16V... slide out the wire of it from PSU side. and turn on check the pins of it if it go high to 18V.
                        • 12307
                        • U.S.
                        #31
                        Yep, check GH12E voltages, don't think it should run that hot.
                          • 12307
                          • U.S.
                          #32
                          Great pitures bytheway, these detailed pictures are a fine example of what's needed by the helpers.
                          • EazyBone
                            • Jun 2023
                            • 1361
                            • United states
                            #33
                            Gh12E gets 0v, 3.28, 5.1 and opposite side gets 3.28
                            TV won't turn on but Tcon doesn't get any V to fuse on either side, with or without WiFi disconnected
                            I don't see a service port, there's a headphone jack between HDMI and USB
                            Yes 18v reads 16.6 actually . I don't know what you mean slide out the wire and check for 18V. Do you mean disconnect it from the harness as a single wire?
                            Here's some pictures Sony lol
                            • EazyBone
                              • Jun 2023
                              • 1361
                              • United states
                              #34
                              Update 2 seconds later Lol
                              I touched this specific cap to test voltage out of the other area that's getting hot and when I did the backlight flickered and then turned on. I didn't have time to check other voltages, but I was able to check one 18v pin and it had come up to 16.8v before I realized I did something. Help now???? Lol
                              Now the TV red standby light doesn't come on anymore lol and voltages are now back to main disconnected from mb voltages
                              Now everything is dead lol. I shorted something touching that exact area or something.
                              As a note the 4R7 component was getting hot and is the other hot spot seen in thermal. Only 115F but still hot compared to other 4R7
                              • Diah
                                • Feb 2013
                                • 6499
                                disconnect MB from PSU and check which V you have on the socket
                                • Diah
                                  • Feb 2013
                                  • 6499
                                  by the way the marked part you touched are R not C..... if you shorted with chassis possible one of the R get Open
                                  • EazyBone
                                    • Jun 2023
                                    • 1361
                                    • United states
                                    #37
                                    They are 12v (is 10) 18 v (is 14)
                                    Hisense 272945 is board and literally no one has it lol. The luck
                                    • Diah
                                      • Feb 2013
                                      • 6499
                                      you have service port.... what about close to tuner i can see there are R connected to the jack as rx tx gnd
                                      • EazyBone
                                        • Jun 2023
                                        • 1361
                                        • United states
                                        #39
                                        You are correct, I never knew they looked that way. Wouldn't even know what to do with it.
                                        I think we are dead now, no replacement available currently so I'm gonna mess around with it but I think it's done lol. At least verified that it was the motherboard most likely and will keep in case I run across one.
                                          • 12307
                                          • U.S.
                                          #40
                                          So the tcon fuse is good, showing continuity with a probe on each end, but you have no 12 volt on either side? then no voltage getting to tcon.
                                          • RossMoodley1967
                                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                            by RossMoodley1967
                                            Hello
                                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                            03-01-2024, 06:07 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • BadCapex
                                            Hisense main board surrogate evaluation
                                            by BadCapex
                                            I am yet another unfortunate owner of a 65H6570F with a main board that failed due to an inherent flaw with the eMMC.
                                            Reference: https://www.badcaps.net/forum/showthread.php?t=117406
                                            The exact replacement board for a 65H6570 model TV is RSAG7.820.8831/ROH (aka 265223, aka 244991). It is very rare or expensive ($150+) to purchase currently and arguably not worth it if they're all just ticking time bombs.
                                            A very similar board was identified in the above referenced thread, RSAG7.820.10315/ROH. It is more reliable, cheap, plentiful, and...
                                            10-22-2023, 04:36 PM
                                          • LemoneyF
                                            Hisense 50r6- no standby, no power, bad main board?
                                            by LemoneyF
                                            Hi all
                                            I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                            I have tested the power supply and found the following:
                                            363V and 373V across the input caps
                                            bri- 0V
                                            ana- 0V
                                            vamp-17.03V
                                            vamp-17.03V
                                            stb- 0V
                                            12V- 9.3V
                                            12V- 9.3V
                                            To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                            10-12-2022, 07:44 AM
