Panasonic TC-P65V10, Plasma
  • jbrand
    • Aug 2023
    • 10
    I have a Panasonic TC-P65V10, Plasma, from 2010. The screen on the unit often dims, then brightens back, and even sometimes completely blacks out, but comes back after a few seconds.
    It is not throwing any power led codes. I opened the panel and tightened all the board ground screws. It still does it. It won't do it until after the unit has been on for about 15 minutes.
    When it does it, the SS board buzzes a bit, and the P sustain (?) board transformer seems to buzz.
    I am not sure if it's worth looking at or if this is a common problem that you may already know what the issue might be. I'd really like to save it if possible.
  • nomoresonys
    • 12332
    • U.S.
    Re: Panasonic TC-P65V10, Plasma
    Good clear straight on pictures of each board and one of the whole back as to see how everything is connected.
    • jbrand
      • Aug 2023
      • 10
      I just fired it up after reseating the cables from the SS to the P board. Watching the clock to see when it starts acting up again.
      I see the VSUS voltage potentiometer on the P board. I've not touched it yet.
      In the meantime I am prepping and posting pictures. A few minutes they'll be ready.
      • jbrand
        • Aug 2023
        • 10
        Did not take long for it to start doing it again. Had difficulty getting full single picture. Back up against wall. If not perceivable please advise and I'll move the unit so I can get behind it better.
        Caps visibly look good.
        • nomoresonys
          • 12332
          • U.S.
          Make sure your solder joints are all good on that buzzing transformer, underside of board of course.
          • jbrand
            • Aug 2023
            • 10
            Good idea. Going to go put my ear on it one more time to be sure, then I'll pull it.
            How to discharge those caps so I don't kill myself? I know basic electronics, not a pro.
            • nomoresonys
              • 12332
              • U.S.
              Unplug tv for a while and use a resistor, retest cap to make sure it's 0 v or very low to be safe: https://www.youtube.com/watch?v=2TcVZ2opuNc
              • jbrand
                • Aug 2023
                • 10
                Perfect, thanks. I will check that video.
                Yup, it's this one for sure. None of the other coils buzz like this one does. And the buzz sound changes as the picture fades/brightens. It's either that component or something controlling it. The small board LEDs on the SS and SC never go out. They stay constantly lit.
                I'll pull that power board and check the solder joints.
                • nomoresonys
                  • 12332
                  • U.S.
                  That's always a good thing to check, now when you retest, make sure you put in every holding/ground screw and they are tight, so many have shorted shit out by only putting back in a few screws.
                  • jbrand
                    • Aug 2023
                    • 10
                    Are these points for discharging the all the caps on the board? Looks like it would be.
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      https://www.badcaps.net/forum/showthread.php?t=94861
                      Check your SS board too, I have the 58 inch version of this TV and your SS board is the same part model, this is something that will happen to all these TVs as wear occour.
                      • nomoresonys
                        • 12332
                        • U.S.
                        I don't think I have run across those before but it seems like that is what they are for.
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          those are vsus test points, I guess you can use them to short it if you want some sparks.
                          • nomoresonys
                            • 12332
                            • U.S.
                            Oh crap, bad guess from me, haven't dealt with plasmas for quite a while, guess that discharge label there is just a warning to discharge something.
                            • jbrand
                              • Aug 2023
                              • 10
                              It was my guess as well. Where the placement is looks like it, but yeah they are labelled with TP's. I didn't get a chance to pull the board yet. Hunting around for a high watt resistor. Might have to pluck one out of something.
                              My gut tells me it is the power board issue, but not a cold solder. When it was going haywire I put pressure on that transformer. Didn't change anything.
                              I found a replacement board. It's on its way here but won't arrive until late next week. I am still going to pull this board and look though.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                Take a look at the 5 big blue capacitors on the ss board for cracks on any of them .
                                • jbrand
                                  • Aug 2023
                                  • 10
                                  Thanks. All the caps on all boards, visibly, appear to be in good condition. No cracking or leaking.
                                  I think this transformer has a crack in it's housing, possibly.
                                  • jbrand
                                    • Aug 2023
                                    • 10
                                    Thank you to everyone that helped. New power board arrived. Amazed I could locate the correct revision board but I did. Put the new board in this morning and so far so good. Transformer not hissing at all.
                                    Inspection of the old, original board, did not show any obvious signs of issue. Mounting of transformer appears solid. There are 4 IC's mounted on some heat sinks. I suspect one of those was bad perhaps? If this buy me another year or two of use I'll be a happy camper.
                                    Thanks again.
                                    • nomoresonys
                                      • 12332
                                      • U.S.
                                      Glad to hear it, thanks for followup.
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • stecos
                                        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                        by stecos
                                        Hi everyone!
                                        I happened several times, in the search for help from the web, to consult this very interesting forum.
                                        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                        Having said that I come to the gist of my post on the forum as the title suggests.
                                        For my passion for technology I'm now collecting several...
                                        11-28-2022, 11:39 AM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                        After all of...
                                        07-13-2024, 08:14 PM
                                      • canadaboy25
                                        Panasonic TC-P54VT25 No image. A or D board?
                                        by canadaboy25
                                        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                        01-17-2021, 01:06 AM
