Help sourcing T-CON board for Philips 58pus8555/12
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    as title says, I'm trying to hunt down a working t-con for philips 58pus8555/12, seems like new or used working t-cons for this model are non existent. If anyone has any idea where I could buy one I would appreciate it.
    Thank you!
  • lotas
    • Jan 2016
    • 4573
    • Russia
    Re: Help sourcing T-CON board for Philips 58pus8555/12
    https://www.tvparts.co.uk/lcd-tv-spa...ps-58pus750512
    https://aliexpress.com/item/1005005448772150.html
    https://aliexpress.com/item/1005004380751613.html
    https://tvonderdelen.nl/en/ccpd-tc57...0-58pus8555-12
    https://es.wallapop.com/item/despiec...5-12-912709669
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      Thank you!
      Do you happen to know if 7505 or 8505 boards compatible with the 8555? They looks the same visually but I'm not too sure.
      the serial no. on the boards seems the same (CCPD-TC575-009 V1.0) but maybe firmware is different?
      • lotas
        • Jan 2016
        • 4573
        • Russia
        Under your panel (matrix), enter your three-digit code, if anything.
        • Gjackson
          • Aug 2021
          • 134
          • Malta
          Good info, thank you
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
