Samsung LED TV Model UA49N5000AR (Flipped image)
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi Guys, this is the second time that I see this exact same issue on a Samsung. The tvs image is upside down and the set refuses to enter service mode (info, menu, mute, power).
    To me it seems that the firmware has become corrupt and this prevents service mode access. Has anybody on this forum ever fixed this without changing the motherboard?
    I tried to load firmware from Samsung website but as usual this is shit. The software version available online is older than what is loaded on the tv.
    • 12184
    • U.S.
    Re: Samsung LED TV Model UA49N5000AR (Flipped image)
    They can flip, sometimes it's just a glitch, one thing to do is make sure nobody put a mismatch mainboard in there.
    • Storyteller12
      • Jun 2020
      • 624
      Try the service remote or if you have an old android phone with ir blaster you can download an app.
      I believe you push (menu, 3speed) to enter service menu. This is a master service menu and differs from the one you were trying to use
      • angelos
        • Dec 2012
        • 571
        • South Africa
        Hi Storyteller12,
        Are you saying i push the menu button 3 times in succession quickly? Would this be in standby mode?
        • angelos
          • Dec 2012
          • 571
          • South Africa
          Does Samsung have a service remote like LG? What is its part number then i can google it?
          • vinceroger69
            • Mar 2012
            • 6714
            maybe this apk https://apkcombo.com/service-remote-....servicercsam/
            • Storyteller12
              • Jun 2020
              • 624
              Hi Storyteller12,
              No, it's a button labeled 3speed. I made a mistake as you push
              info then 3speed button
              • angelos
                • Dec 2012
                • 571
                • South Africa
                Using the service remote, when i press "Factory" the tv set says "Not Available"
                • angelos
                  • Dec 2012
                  • 571
                  • South Africa
                  I added a picture of the service remote i used that did not work.
                  • Storyteller12
                    • Jun 2020
                    • 624
                    With the tv on you press “info, then factory” it should pull up the service menu
                    • angelos
                      • Dec 2012
                      • 571
                      • South Africa
                      I will try that later today when I am in front of it. Thanks so far.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        What the hell are you talking about???
                        Get lost loser.
                        See the warning triangle under everyone's username ?
                        Click it and report it as spam.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          doesn't the asian versions use like america version something like 1,4,2,power? Or info,1,4,2...
                          Try pressing Exit for 15 seconds, this resets the tv, or you can erase the settins eeprom.. maybe hotel mode has get in.. try search service manual
                          • angelos
                            • Dec 2012
                            • 571
                            • South Africa
                            Hi Davi.p
                            I was on leave until now and got to look at my messages. Tell me how do you erase the settings in the eprom and what are the consequences of doing so?
                            Regards
                            A Anagnostou
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4326
                              • Italy - Milan
                              Putting all FF to the settings eprom is not harmful because main sw rewrites it with default stored in main flash ic..
                              • Storyteller12
                                • Jun 2020
                                • 624
                                I’m assuming the service remote didn’t work?
                                • lotas
                                  • Jan 2016
                                  • 4597
                                  • Russia
                                  Yes, but you will lose everything: serial numbers, regions, MAC address....
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4326
                                    • Italy - Milan
                                    I don't think so.. are you sure? my guess is another, original settings are stored in main memory, both current and default.. if the boot software finds empty eprom it rewrites it.
                                    • lotas
                                      • Jan 2016
                                      • 4597
                                      • Russia
                                      This option worked in older models, but it will not work in new “smart” models; with a clean eeprom it may not even turn on.
                                      • angelos
                                        • Dec 2012
                                        • 571
                                        • South Africa
                                        I'm assuming the service remote didn't work?
                                        I have ordered one from Aliexpress but it has not come yet. I took the TV to a colleague of mine and he got it sorted. His explanation on how he got the tv sorted was rather sketchy so i left it at that.
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
