Faulty CRT AKF12/Philips CM8500: bad flyback?
  • tony359
    • Oct 2018
    • 264
    • United Kingdom
    I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
    What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
    There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
    Can it be a short somewhere else? Or does the flyback short when it fails?
    Also, where can I find something that explains me the principle of operations of a TV, particularly how the horizontal circuit works with the flyback? I've been staring at schematics for a while and I am not sure I understand why the horizontal pulse ends up in the flyback!
    Thanks!
  • R_J
    • 9610
    Re: Faulty CRT AKF12/Philips CM8500: bad flyback?
    Check the horzontal output transistor and damper diode one may be shorted, usually is the flyback shorts the horz. o/p transistor will also short. There is also a electrolytic cap 22µf (C483?) on T401, it may be bad as well
    I would also replace the small electrolytics in the primary switcher, they may be bad not alowing the power supply to run at full power.
    • tony359
      • Oct 2018
      • 264
      • United Kingdom
      Thank you!
      I should have posted the schematics, it took me a while to find them as it's the 240V version and not 110V. They're attached.
      is it C461 on T401?
      I'll check the horizontal transistor even though from preliminary tests it looks fine. Damper diode is D461?
      Good point about the SMPS not being able to keep up the voltage under load. I'll test with some dummy loads for sure.
      Back on the basics, I see the horizontal transistor is maybe driving the flyback? I'll research but any pointers would be great thanks!
      • R_J
        • 9610
        TS461 is the horz drive transistor, it drives T401 which is the horz. drive transformer, TS467 is the horz. o/p and the damper diode is D467,D468
        C462 can cause problems if it is bad/open the horz pulse will be distorted and not drive the circuit properly.
        in the power supply I would first replace C122 1µf/50v and maybe C116 47µf/16v
        • tony359
          • Oct 2018
          • 264
          • United Kingdom
          Thank you.
          How can I diagnose a bad flyback? Would it read as a short? I guess it would normally read a very low resistance?
            • 31267
            you need a "ringer" to test a flyback.
            the problem can even be a short after the flyback on the seconary rails.
            if you desolder the flyback you can meter the output pads for shorted diodes etc.
            you can also see if the overload has gone away that is drawing the B+ voltage down.
            on that subject, there should be a smoothing cap on the B+ rated anywhere between 160v and 250v - check it.
            • tony359
              • Oct 2018
              • 264
              • United Kingdom
              Thanks, I read up online and educated myself about how the flyback works and how it's connected.
              I'll poke around and indeed I'm thinking of removing the flyback to see whether the short goes away when it's de-soldered.
              I'll take a look at those caps.
              Thanks again as usual, I'll report back!
              • tony359
                • Oct 2018
                • 264
                • United Kingdom
                The diagnosis seems to be pointing to the flyback unfortunately.
                - The Horizontal transistor tests fine
                - The capacitors you mentioned test fine
                - all diodes seem to be fine
                - No shorts I can detect on the board
                - the PSU works fine with the main PCB disconnected and driving some dummy loads
                - I removed the flyback, no shorts on secondary windings and the PSU powers up the board fine with the flyback removed.
                So it's either something on the secondary circuits or it's the flyback itself. I'd say it's likely the flyback.
                Thanks for all your help so far!
                • tony359
                  • Oct 2018
                  • 264
                  • United Kingdom
                  little update: the new flyback (and new HOT transistor just in case) fixed the monitor.
                  https://youtu.be/3-LrkMFsfw8
                  But a week later it failed again
                  I haven't had a chance to take a look yet but I can see 15Khz coming out of it so it seems that part of the circuit is working. But no HV and no picture.
                  • Diah
                    • Feb 2013
                    • 6501
                    at time of CRT Philips & Grundig ... we never replace Flyback Transformer unless its shorter or burned , we repair them air it as any other transformer repair usually there will be cutting line on one pins leg.. we make hole to free the legs from foam then extend the wire to the pins ..LOL
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                    • Stephen
                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                      by Stephen
                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                      02-06-2025, 12:03 PM
                    • grandad99
                      philips 58PUS8105/12 horizontal lines
                      by grandad99
                      hi all and hoping i could get some help please.
                      my philips 58PUS8105/12 has started acting weird.
                      its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
                      tv prob 3 years old and only used on weekends for a few hours so not done much.
                      i popped the back off and cleaned the ribbon contacts all to no...
                      08-01-2023, 10:37 AM
                    • aaronkatrini
                      Help me find the short circuit on this WORKING Nvidia GTX1650
                      by aaronkatrini
                      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                      04-18-2024, 03:15 PM
                    • Geeker007
                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                      by Geeker007
                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                      01-28-2025, 03:31 PM
