Sharp LC-C4655U Flashing OPC and Power lights.
+ More Options
Posts
  • berrmich
    • Aug 2023
    • 30
    I have the above TV. Black screen. Power blinks 2 times. OPC blinks once. Plug in with channeldown/volup. Powers up with solid green power but no light. I removed, cleaned and tightened the screwed on the inverters. I tested plug coming from the power supply to the inverter board when unplugged. INV12V shows 7.4 V DC. INV60V shows 0.1 or something like that. After plugging in the cable I don't get meaningful voltage from either one. (I measured after booting the TV with channeldown/volup.)
    Is this a bad power supply? Or am I measuring something wrong.
    -Mike
  • zwarder
    • Oct 2013
    • 45
    • United Kingdom
    Re: Sharp LC-C4655U Flashing OPC and Power lights.
    What psu is in it ?
    Usually a RUNTKA***** number
    Some good info in this thread
    https://www.badcaps.net/forum/showthread.php?t=44622
      • 12099
      • U.S.
      Good focused straight on pictures of each board and one of the whole back as to see how everything is connected.
      • berrmich
        • Aug 2023
        • 30
        Thanks! Here are some pictures.
          • 12099
          • U.S.
          Check voltages on PD1, meter set to vdc, neg. probe on metal chassis ground, pos. probe on each of the 12 pins, report results as pin 1 sv signal and the voltage, do that for each pin.
          • berrmich
            • Aug 2023
            • 30
            1 - 0 (13.7V_Signal)
            2 - 0
            3 - 0 (13.5V_Audio)
            4 - 0
            5 - 0 (SGND_Audio)
            6 - 0
            7 - 0 (SGND)
            8 - 3.18V
            9 - 0 (AC_DET)
            10 - 0 (PS_ON)
            11 - 0 (BU5V)
            12 - 5V (PNL_POW)
            Pin number - Voltage measured (Description)
            Just to be clear, only pin 8 and 12 had any voltage.
              • 12099
              • U.S.
              Not exactly sure what all pins need to be connected but you can try unhook cable from powerboard to mainboard, I do it on mainboard side, trace the wires out from pin 8 and pin 10 take about a 1k ohm resistor and jump from those two at the cable connector end, so the cable will be unhooked at the mainboard leave that end uhnooked for test, put jumper resistor in and retest those 12 pins voltages and see what you get.
                • 12099
                • U.S.
                You don't have any voltage on the AC_DET, I'm thinking there should be voltage there on this one but not sure, someone else may remember, haven't worked with a good old ccfl tv much lately.
                • berrmich
                  • Aug 2023
                  • 30
                  So I measured those without the plug in. When the plug is in I get:
                  5v on pin 12
                  0.7v on pin 9 (AC_Det)
                  3.0v on pin 8
                  The rest are 0.
                  This is when starting the TV with channel down / vol up to bypass the error.
                  • R_J
                    • 9535
                    This is the US model board so the pin numbers for plug PD(US) are different than PD1(EU)
                    1-13.5 (sig)
                    2,3-13.5 (aud)
                    4,5 (aud gnd)
                    6,7 (sig gnd)
                    8 (ac_det)
                    9 (PS_ON)
                    10 (pnl_pow)
                    11 (sgnd)
                    12 (BU5V)
                    To turn on the power supply board (disconnect cable from main board) connect BU5V to PS_ON This should give 13.5v and INV60v
                    • berrmich
                      • Aug 2023
                      • 30
                      Ok. Now I'm a little confused. PD1 is EU. PD is US. Probably makes a little more sense. PS_ON is still only 0.7V. I'll see if I can get a resistor tomorrow and see if 3V will turn everything on? Could be the main board then?
                      Also PS_ON is only 0.7v if I start it with channeldown/volup. Otherwise it is 0.
                      Pin 1 - 0 (13.7V_Signal)
                      Pin 2 - 0 (13.7V Audio)
                      Pin 3 - 0
                      Pin 4 - 0 (SGND_Audio)
                      Pin 5 - 0
                      Pin 6 - 0 (SGND)
                      Pin 7 - 0
                      Pin 8 - 3V (AC_DET)
                      Pin 9 - 0.7v (PS_On)
                      Pin 10 - 0 (PNL_POW)
                      Pin 11 - 0 (SGND)
                      Pin 12 - 5V (BU5V)
                      • R_J
                        • 9535
                        If you are carefull and don''t connect B5V to ground, you don't need a resistor, there already is a 10kΩ (R7300) on the board
                          • 12099
                          • U.S.
                          The resistor is just for safety so nothing shorts out in case you jumper the wrong pins, not needed if it's jumpered correctly, so looks like you want to jumper 12 and 9, then see if you get those missing voltages.
                            • 12099
                            • U.S.
                            Pin 3 - 0
                            Pin 5 - 0
                            Pin 6 - 0 (SGND)
                            Pin 7 - 0
                            Pin 8 - 3V (AC_DET)
                            Pin 11 - 0 (SGND)
                            Pin 12 - 5V (BU5V)
                            Those voltages are correct, this is what you should see when the tv is plugged in and just in standby, then when you turn it on you would get the rest of the voltages, when you jumper those pins if you get the missing voltages and the correct voltage on ps-on, then you know that part of the powerboard is ok.
                            • berrmich
                              • Aug 2023
                              • 30
                              Pin 1 - 13.2V (13.7V_Signal)
                              Pin 2 - 13.2V (13.7V Audio)
                              Pin 3 - 13.2V
                              Pin 5 - 0
                              Pin 6 - 0 (SGND)
                              Pin 7 - 0
                              Pin 8 - 3.2V (AC_DET)
                              Pin 9 - 5v (PS_On)
                              Pin 11 - 0 (SGND)
                              Pin 12 - 5V (BU5V)
                              With Pin 9 and 12 Jumpered.
                              Mike
                              • R_J
                                • 9535
                                Check the back of the board for IC9703 (BU5V to B3.3v) regulator, that feeds Q9701 (lower left corner in picture)
                                One other thing to check would be if Q9702 is being triggerd by the OV_VLT line
                                LC42d65u service manual has the schematic of the main board
                                Did you check that both fuses are ok on the inverter board?
                                • berrmich
                                  • Aug 2023
                                  • 30
                                  I don't see IC9703 or Q9701 on my main board. Yes I am getting INV60V and 12V with the jumper.
                                  My main board is KE716 XE716WJ
                                  Thanks!
                                  • berrmich
                                    • Aug 2023
                                    • 30
                                    Picture.
                                    • berrmich
                                      • Aug 2023
                                      • 30
                                      Pin 5 on IC9703 reads 3.3V
                                      Not sure how to check the second thing you said.
                                      I did not see fuses there. I checked the one on the power board.
                                      • R_J
                                        • 9535
                                        Something may be causing the power suuply not to turn on, It may be due to an error from the inverter board. If you force the tv ON with the button combination, do you have the inv12 and inv60v? if you do and you don't have backlights, the fault may be on either the inverter or maybe a bad ccfl or bad ccfl connection in the panel. and NOT the main or power supply boards.
                                        Fuses on inverter board are in front of plug LA (post 4 second picture) Check for voltage (60v) on L7500A and L7501A
                                        Q9701 should have 3.3v on pin4 and when the power button is pressed pin3 should also be 3.3v, Pin 2 should also change when the power button is pressed
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • TVAddict
                                          Sharp LC-32D44U - Power and OPC lights flashing
                                          by TVAddict
                                          Hello everyone, so the problem is the tv would seem to power up when i hit the power button as i would hear a relay click, sometimes it may give me a good picture for about 5 secs or so, sometimes i get a black screen, then shortly after it will click back off and i get power and opc lights flashing together twice followed by one flash of the opc light then it repeats.
                                          Please correct me if i'm wrong but i understand the flash sequence indicates a possible power supply problem, can anyone say if this is accurate information? So going on that i went ahead and tried a factory reset, checked...
                                          02-09-2022, 06:36 PM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
