Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
  • Diah
    • Feb 2013
    • 6435
    Originally posted by Benbuke21
    Hello Jingasharo, I realize you have been kind enough to respond to my inquiry
    don't listen to Spam solution..... from the name call of parts he never have read TV or Electronic schismatic in his life ______ so his post
    Originally posted by jingasharo
    Hi Guys, It was issue with the "address board".
    SPAM
    • Benbuke21
      • Dec 2023
      • 9
      Got it! Thank you Diah for letting me know. Have a wonderful holiday season and thank you for taking the time.
      • jingasharo
        • Dec 2023
        • 8
        SPAM
        Lol spam solution? Youre a joke, tell us your solution then buddy?
        • jingasharo
          • Dec 2023
          • 8
          Hello Jingasharo, I realize you have been kind enough to respond to my inquiry but I wanted to ask another question. Did your TV repair have same two black lines as my tv and other OP? Second question is can you give a range for repair $$? Reason for asking is pretty good TV repair guy told me it's 90% a defective display panel. I've seen over 20 of these same TV's online in the States with same exact issue. I'm guessing this is a complex repair as this TV guy wanted nothing to do with it. Regardless thank you to all of you who took the time to respond. I will absolutely share. All the best!
          Hey, yes exactly the same issue. The tech was referring it as a panel issue. Fix was $400. Issue in the address board/chips attached to panel is what my tech told me.
          • Benbuke21
            • Dec 2023
            • 9
            Thank you Jingasharo for returning the answers to my questions. It was unnecessary for anyone to imply you are not trying to be helpful. You took the time to try to be as helpful as you could and for that I can only be appreciative. I wish you well in future projects. Be well.
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • thelankanguy
              Sony KD-55X9000F TCON Issue
              by thelankanguy
              The TV shows a black screen with no image.
              TCON ribbon connectors were disconnected individually for image and there was no half image even.
              Later both ribbons were disconnected and TCON voltages were tested.
              12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
              There is also a short to ground in this circled inductor.
              Is this a TCON issue or something else ?...
              12-13-2024, 12:27 AM
            • stav242
              Sony KD-55X8509C white flashing/pulsing LED
              by stav242
              I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
              On inspection, there was no physical issues.
              I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
              - this seems to indicate repairing required, done by Firmware update.
              so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
              Inserted the drive and repowered the TV.
              LED changed to white flashing/pulsing ... and it sat there for over an hour.
              i was unsure what was happening so repowered the TV and now it just...
              01-08-2024, 07:39 AM
