Strange problem with Sony XBR-85X850G 85" LED tv
  • mitsu2k
    • Aug 2013
    • 219
    Re: Strange problem with Sony XBR-85X850G 85" LED tv
    Davi.p, is there any method you know of to try and guess the possibly bad protection diode before I start removing one by one? What about freeze spray? I did try and get a temerature reading using infrared thermometer but I could not get any readings that seemed abnormally hot.
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      if they are tvs diodes the fail is shorted . look up the datasheet pinouts and look for shorts . semiconductors have a habit of failing short .
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4463
        • Italy - Milan
        already said.. the problem them eventually get short under tension so you can't test them with MM, the only test that turns in mind is to heat them one per test with soldering stick then test if image is fully ruined at power on..
        • mitsu2k
          • Aug 2013
          • 219
          Now I understand what you are saying. Your are saying that the fail possibly is dynamic and only fails under load. So yes in this case it would be impossible to test with mm. The screen looks perfect for the first 1 or 2 seconds after powering on. But then the lines appear. So you are correct, the problem is dynamic. I am just so afraid of causing other damage while trying to remove them. The tv is very large and the panel boards sit at an angle so it is very difficult to get the proper angle. I do have a hot air station but that may be to risky die to the proximity of the ribbon cable connector. I will have to shield it very well. The blob of solder method may work but due to the angle of the board, I'm afraid solder will just run down the board. I will keep thinking of a good method.
          Question, should the tv still work with those diodes removed?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4463
            • Italy - Milan
            the tv uses the diodes only in a case of over voltage so for a test aren't necessary, but must be populated next soonest possible. I have never done this procedure, i can only try to suggest you the smallest nozzle and the lowest possible air pressure with high temperature cause the diode packs are ultra small, you need a decent air station, some skill, good eyes, steady hand, a decent plier for smd works, no expensive things to be clear..
            If you have a cutter with brand new blade you can try detach it by small pressure..
            • zomi
              • Nov 2011
              • 509
              #26
              You can try flux and retouch them with leaded solder
              will make it easier to remove then.
              • zomi
                • Nov 2011
                • 509
                #27
                Also kapton or similar heat resistant tape on the plastic connector
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4463
                  • Italy - Milan
                  #28
                  aluminum tape/foil is better
                  • zomi
                    • Nov 2011
                    • 509
                    #29
                    @davi.p would appreciate your advice on my thread https://www.badcaps.net/forum/showthread.php?t=114225
                    I have a similar issue maybe ?
                    • Chrissygizmo
                      Sony KD-55XG9505 lines on screen problem
                      by Chrissygizmo
                      Hello again everyone,
                      This is my latest mission, to try getting this Sony tv back to normal working order…
                      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                      02-19-2025, 11:31 AM
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      The TV does not turn on, the standby indicator is on. All voltages are present.
                      Emms is dead. Not readable, not detected.
                      Replaced emmc.
                      But with another dump there is no launch
                      Terminal log
                      UART
                      AC_ON
                      RPMB key is not yet programmed
                      HASH1_VERSION=0x00000000 64bit
                      E-B
                      FDE enabled
                      layout pattern onebin by SAR7,0...
                      06-01-2025, 02:11 AM
                    • crackedprint
                      Sony HCD-HX80R Amplifier Volume Control Problem
                      by crackedprint
                      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                      I have tried a Cold Reset as per the service manual.
                      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                      I have looked all the way through the service manual and tried many online...
                      01-21-2025, 12:18 PM
                    • retrorepair
                      SONY KDL-40P3600 Picture Problem
                      by retrorepair
                      Hello gurus, hope you can assist me...
                      I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                      I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                      Thanks in advance.
                      10-11-2024, 05:12 PM
                    • guruji
                      Sony mbx-266 problem
                      by guruji
                      Hello
                      I this Sony mbx-266 it powers
                      on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
                      07-25-2025, 08:10 AM
