Sony 65xd9305 bad panel ?
  • zomi
    • Nov 2011
    • 509
    Came to me with a dead dps
    repair done
    but have some lines on the screen
    not the t con
    have tried with another t con.
    how do you do the tape cut off with 4 cables coming from the tcon
    pics where u get white screen and lines is where one set of the tcon cables going to the lcd have been removed.
  • zomi
    • Nov 2011
    • 509
    Re: Sony 65xd9305 bad panel ?
    Is this case of these diodes starting to fail ?
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      can you isolate which side is causing this?
      • zomi
        • Nov 2011
        • 509
        on both sides unfortunately
        not been able to isolate
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4463
          • Italy - Milan
          To block the lines you must follow tcon serigraphs, clock markings especially, post a decent tcon picture, no flash only sun light
          • zomi
            • Nov 2011
            • 509
            tcon
            hope thats is clear enough
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4463
              • Italy - Milan
              i don't find much on the component side, is there any test point on the under side?
              • zomi
                • Nov 2011
                • 509
                been unwell, have pics of lcd board with test points
                did you mean this board
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  These should be the clock lines highlighted, use continuity test to track to which pins they lead from the t-con cable, then block them with tape, for utmost precision, you would remove the resistors one by one until you figure out which signal is causing this.
                  • zomi
                    • Nov 2011
                    • 509
                    The clock lines don't trace back to the tcon..
                    I will double check again tomorrow, late and bad lighting
                    But i couldn't trace them back..
                    may have to just try removing the resistors and see that way maybe
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      At least one side traces obviously to that ic next to them, I saw that but in all TVs I remember they came from the t-con instead, and it's easier and much less damaging to block the signal in the cable if possible.
                      For the other side it then must go into some other ic into the board.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4463
                        • Italy - Milan
                        This screen design is slight different from the others, i have understood how is, the clock signals in the low voltage versions (CPV1...2...) starts.from the tcon and arrive onto the distribution boards into the square chip or the other one, in this the clocks are level shifted towards the panel, it is possible some gate drivers gone bad but if i remember the photos there are not the most typical signs, there is a possibility the level shifter chip is bad, one of the two in the sides.. replacing this is a waste of time for me cause the only few.you.will find on the market are bad parts, i'm experiencing the same situation... to ensure this you must probe with.scope.or frequency meter the output clocks on the biruslapio photo, compare between them
                        • zomi
                          • Nov 2011
                          • 509
                          The 2 ic
                          Added pictures
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • rimwall
                            Sony KD-65x8500b - bad Tcon or panel?
                            by rimwall
                            Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                            a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                            b) the Tcon board is malfunctioning,...
                            10-24-2023, 07:58 PM
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • AK_777
                            Sony KD-65A1 Repair – 4 Red Blinks Error
                            by AK_777
                            Hi everyone!
                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                            02-20-2025, 04:15 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
