TV Philips 43PUS8505/12 - horizontal line and picture jumping
  • betmen
    • May 2019
    • 90
    • Croatia
    TV is Philips 43PUS8505/12, bought in 12/2020, so the two-year warranty has expired about 5 mounth ago...
    Problem is that 15 minutes after TV is turned on, the horizontal lines appear and picture start jumping up and down.
    I suspect that T-CON is faulty when wormed up...
    I separated all the cables from the T-CON and cleaned them but there is no change.
    Eco mode is disabled, software is up to date, I make factory reset and reinstal TV from TV menu...no change, problem is stil here.
    Anibody have some thoughts?
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: TV Philips 43PUS8505/12 - horizontal line and picture jumping
    The name of the display ?
    • betmen
      • May 2019
      • 90
      • Croatia
      Here are the pictures of the stickers...
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        Try to disconnect on one side of the tcon and look at the image
        • betmen
          • May 2019
          • 90
          • Croatia
          I tried that with both cables, after few minutes same error appears.
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            Check the temperature D001-003
            • betmen
              • May 2019
              • 90
              • Croatia
              can`t find this on my tv...
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                Have you looked at this plats ?
                • betmen
                  • May 2019
                  • 90
                  • Croatia
                  I replaced T-CON board and problem is remained.
                  Then I noticed that D007 is very hot when tv is working, so hot that you can`t keep touch it with the finger.
                  When I disconnect cable from T-CON board to the panel board on this side the rest of the picture is ok with no interaptions.
                  When I disconect cable on other side the problem is remaining.
                  So it look like D0007 on panel board on ane side is bad. I can`t find any shorted element with multimeter.
                  Is there any repair possible or not?
                  • lotas
                    • Jan 2016
                    • 4805
                    • Russia
                    You carefully remove it (tvs diodes) and that's it, you can remove all the others, they are more problems than good.
                    • betmen
                      • May 2019
                      • 90
                      • Croatia
                      Will TV work ok without this diode?
                      • William1967
                        • Nov 2017
                        • 217
                        • Netherlands
                        Yes it will.
                        • tech9pc
                          • Sep 2021
                          • 50
                          yes I have 3 RCA's with same problem, nice tv's 4K but lost interest and sure as hell not going to spend hundreds of dollars on replacement parts if not going to solve the problem. Maybe this post will renew my interest to have another look. Have heard a lot about removing useless diodes on several brands like samsung, lg, rca etc and problem solved. Hope it works for you ... will be keeping an eye on this post.
                          • betmen
                            • May 2019
                            • 90
                            • Croatia
                            I removed this diode and tv is working without errors for now, I tested it for 35 minutes...not quite understand it myself what is this diode for and how tv is working without it but I am satisfied for now...
                            thanks for the advice...
                            • petehall347
                              • Jan 2015
                              • 4445
                              • United Kingdom
                              diode is tvs .. transient voltage suppressor its there as protection .
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
                              • Rauni
                                Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                by Rauni
                                Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                Read also that we should test what happens if we...
                                10-01-2023, 12:06 AM
                              • cubytus
                                Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                by cubytus
                                Hi to all,
                                I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                01-10-2024, 01:26 AM
                              • Schwoin
                                Philips 243v5lhsb00 Monitor Picture too bright
                                by Schwoin
                                Hey everyone,
                                the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                you can see them on the top half of the photo.
                                At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                03-21-2023, 12:40 PM
                              • mrsith
                                Samsung UE58TU7100K - no picture, vertical line
                                by mrsith
                                Hi.
                                Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                                This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                                Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                                02-07-2023, 11:18 AM
