Hi there,
I've got a Hisense 65P8 and it's stopped displaying a picture 6 months out of warranty.
Pictures attached
I've written out the codes on the stickers as they aren't very legible being so faint.
Power board: RASG7.820.7920 - HLL5066WJ
Main board: RSAG7.820.7969 - HA657700UWGT
T-con board - 55T36-C04 - TT-5565T50C17
I've been doing a lot of research and diagnosis.
Symptoms firstly:
Unit was working one evening, then the image became a set of wide coloured stripes, [not the thin lines some experience, more like a single horizontal line of pixels was brushed up the screen from the bottom]
So I waited a few minutes to see if if was a broadcast issue, tried displaying a menu - still coloured stripes.
Powered it down, unplugged, switched back on and backlights illuminate but there's nothing displayed.
The screen is essentially black [black as in the black of when it's on with the backlights on].
I should add, I have tried the flashlight method to check if anything is displayed, it' blank.
This isn't an uncommon fault, but reading as many Hisense threads as I can locate, there doesn't seem to be a good testing through to definitive fault diagnosis and successful outcome.
I've checked all of the power rails, as noted, backlights are illuminated, no picture, sound works.
There's 12V at the T-com board [fuse checks out] and I've tried the method of disconnecting each of the two t-con to panel connectors one at a time to see if I get one half of the display - I don't, the screen remains black.
Please correct me if I'm wrong, that suggests the panel isn't faulty or damaged, it's not receiving image data.
The T-con is functional electrically [fuse] chips warm when the unit is powered up.
So I've removed the heatsinks, as shown in the photos in preparation for reflowing the Novatek NT72334TBG graphics chip.
Is there anything else I can do to nail it down to the main board or t-con board before I do the reflow.
I don't want to do it just for the sake of it before exhausting all other possibilities.
thanks
Glenn
Pictures attached
Symptoms firstly:
thanks
Glenn
