Philips 50PUS6262/12 (chassis TMP17.7E LA)
  • Jimmy1979
    • Apr 2015
    • 120
    • holland
    Hello does anyone have a schematic of the bufferboard? or clear photos with resistors? I have one burnt resistor and one shorted smd cap.
  • nomoresonys
    • 12186
    • U.S.
    Re: Philips 50PUS6262/12 (chassis TMP17.7E LA)
    Post a good clear picture of your buffer board.
    • nomoresonys
      • 12186
      • U.S.
      The main thing is eliminate the short, I have replaced these caps with same physical size caps from donor boards, for resistor check the ohms of similar good resistors nearby, probably be the same.
      • Jimmy1979
        • Apr 2015
        • 120
        • holland
        I have part number 50t32-sod xr bd.
        Tomorrow I will post pictures
        • Jimmy1979
          • Apr 2015
          • 120
          • holland
          I did this too and I had picture for 1 second and it went off
          • nomoresonys
            • 12186
            • U.S.
            Ok, take that cap off again if you haven't and check the pads where it goes to see if short is gone if you have not already.
            • Jimmy1979
              • Apr 2015
              • 120
              • holland
              I have no short now. But I have to do investigate more tomorrow
              • nomoresonys
                • 12186
                • U.S.
                And you are sure the donor was a cap, designator on board starts with a C, there are some components that look like caps but are not.
                • nomoresonys
                  • 12186
                  • U.S.
                  Recheck your solder work on the cap, was that with a new resistor also?
                  • lotas
                    • Jan 2016
                    • 4597
                    • Russia
                    Remove the TVS protective diode assemblies and replace the resistor again with 100 (10 Om) - this is their disease in this panel and you will be happy.
                    • nomoresonys
                      • 12186
                      • U.S.
                      Ah, ok, those rotten tvs diodes again, should he test them or just yank m out.
                      • Jimmy1979
                        • Apr 2015
                        • 120
                        • holland
                        I changed cap c1204 and resistor r086.
                        I suppose I need to take out 2 diodes d004 and d003
                        And other side too.
                        • Jimmy1979
                          • Apr 2015
                          • 120
                          • holland
                          I will try this thanx
                          • lotas
                            • Jan 2016
                            • 4597
                            • Russia
                            Yes, the resistors R075 and R086 mostly burn out, they must be replaced and the diode assembly D004 removed. The photo shows that R075 is missing.
                            • Jimmy1979
                              • Apr 2015
                              • 120
                              • holland
                              I did not removed r075. Do you now the value? Is this 10ohm too?
                              And other side I only remove d004 too?
                              • lotas
                                • Jan 2016
                                • 4597
                                • Russia
                                Yes R075 - 100 (10 Om)
                                Remove from both sides D004.
                                • Jimmy1979
                                  • Apr 2015
                                  • 120
                                  • holland
                                  I have picture again. Thank you for helping👍🏻
                                  • lotas
                                    • Jan 2016
                                    • 4597
                                    • Russia
                                    Yes, not for anything. Congratulations.
                                    • nomoresonys
                                      • 12186
                                      • U.S.
                                      I don't really know if they are needed or not, a little article there explaining their intended purpose: https://uk.rs-online.com/web/content...s-diodes-guide
                                      • nomoresonys
                                        • 12186
                                        • U.S.
                                        davi pee is/was always harping about how you absolutely must replace theses tvs diodes, BUT of course I wouldn't buy stock based on his recommendation, what does the rest of the brain-trust think?
