L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
  • cekanayake
    • May 2019
    • 16
    Re: L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    Update: Replaced ICM801CS with FSFR2100XSL. Board flashes backlight now while standby light turns on and off.
    Voltages: while main board plugged in
    Pins 7 and 9 (B13v)goes upto 11v then goes down with the backlight flashing
    Pin 17 and 19 (B5v)goes upto 5.3v then goes down with the backlight flashing
    Pin 20 (PS on/off)goes upto 3.3v then goes down with the backlight flashing
    Pin 18 (A5v)has constant 5.38v
    I am wondering what else may be wrong. Any help please.
    ICM801CS heat sink getting to 55c
      • 12200
      • U.S.
      Ok, now try it with the cable from powerboard to mainboard unhooked, see if backlights come on steady and stay on.
      • cekanayake
        • May 2019
        • 16
        Yes. With main board disconnected backlight stays on
          • 12200
          • U.S.
          Ok, now do the test with one cable at a time unhooked from tcon to panel, then try turning on tv, see if you get a display or what happens, best policy is have tv unplugged from power whenever unhooking or hooking cables, so you don't get any errant surges or such.
          • Diah
            • Feb 2013
            • 6376
            my POST #10
            try to slide out the 2 wires of B13V from the socket of pins 7&9 at PSU side, then plug the tv in wall and see if it boot complete and BL stay on. they are for sound and t-CON. if the issue same bootloop... pput them back and remove B5V wire and try
            • cekanayake
              • May 2019
              • 16
              When I take out both(B13v)s (with B5v on)and try it still cycles but the BL does not flash. When I take out the (B5v)s leads(with B13 on)it goes back to doing the original standby flashing twice 5 times over and over but the BL flashes. I didn’t get to disconnecting the tcon cables one by one as that would mean that I have to take this giant tv and lay it flat. Probably do it tomorrow morning. Thank you Diah and nomoresonys.
              • cekanayake
                • May 2019
                • 16
                Ok. Tested with either cable and both cables disconnected from the t on board to the panel and symptoms are the same cycling and flashing the BL. Does this mean fault in PSI or main board or tcon board?
                • cekanayake
                  • May 2019
                  • 16
                  Originally posted by Diah
                  in this case.. u need to check pin A5V if its stable
                  if stable mean pin 20 power on caused by Main boards didn't boot ( boot loop)
                  if its not stable then the issue at PSU
                  So measure A5v shows constant 5.3v does this mean main board fault?
                    • 12200
                    • U.S.
                    #29
                    I think the issue is with the mainboard.
                    • Diah
                      • Feb 2013
                      • 6376
                      A5V are the STBY. so there are 2 scenario of fault
                      1- one Opto coupling which switch PS on are fault/ not stable so the circuit power on off you need to follow PS ON/ OFF pin to know which Opto and test..
                      2- boot loop on MB
                      to be more sure you need to test the power supply complete as stand alone ... when all pins output on the socket correct value and stable include the pins Vamp 13V. at this stage if every things fine then the MB are in boot loop.
                      BTW use 1K ohm R with testing when you bridge A5V to any other ON/OFF pins.
                      • cekanayake
                        • May 2019
                        • 16
                        2- boot loop on MB
                        Ok did the above with 1k Resistor jumped from A5v to each on/off pin results in B13v at 8.04v and B5v at 4.49v will check opto couple next
                        • Diah
                          • Feb 2013
                          • 6376
                          yours PSU had not enough juice ../ weak . BTW you didn't write any things about pns Vamp 13V... so you need to work on the PSU include to measure all CAPs MSR
                            • 12200
                            • U.S.
                            #33
                            Try heating the electrolytic caps up with a hairdryer for a couple few minutes, then try the tv, see if there's any difference and recheck voltages, do it while it's still hot, don't wait til it cools down.
                              • 12200
                              • U.S.
                              #34
                              So do Diah's test in post #30, he can help you, usually involves unhooking cable from powerboard to mainboard and using resistors to fully turn on powerboard, then if the voltages are not correct, need to fix the powerboard as suggested. Try the simple hairdryer test also, need to verify that powerboard is 100 percent, can then move on to other stuff if needed.
                              • cekanayake
                                • May 2019
                                • 16
                                The Vamp pins 11 and 13 are at 8.04v
                                Caps cs801 at 387v cp803/cp804/cp805 at 387v
                                On the cold side caps c9454/c9354 at 191v but c9154 fluctuating between 126v-115v and c9254 fluctuating 190v-160v happens between screen BL flashes bright then goes back to regular brightness
                                  • 12200
                                  • U.S.
                                  #36
                                  Check every diode on the powerboard, some may be on heatsinks, if you have a doubt about any of those caps and some available, just switch them out, otherwise you need to test them with a good cap checking meter out of circuit, you can not get a reliable accurate reading in circuit, if anyone don't believe it just check the pros on youtube with the 200 dollar cap meters, they say the same thing.
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    i cant believe ICM801CS blown and just the fuse got open... there should be at the downside SMT parts went open too.
                                      • 12200
                                      • U.S.
                                      #38
                                      Guess it could be an opto like you suggested earlier Diah, can maybe test them by freezing or heating, and see if the voltages are stable for a bit.
                                      • cekanayake
                                        • May 2019
                                        • 16
                                        Good morning or evening to everyone. I am abandoning this project as I don’t have the time to devote to it and my skills in this field have a lot to be desired. The last thing I checked was the optos and the diodes on the bottom side. I found 2 diodes short and replaced them and found the optos working when I pulled them and checked. This project is beyond my skill level. Thank you for all your help and support. I am willing to share anything from this project with any of you if you need anything please let me know and I will be happy to share them. Thank you all again for all your guidance.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4333
                                          • Italy - Milan
                                          #40
                                          Hi, in this and other series from same year it happened often to be failing transformer, you may have to re wrap it with good wire maybe took from another PS o or new
                                          • Seb932
                                            LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
                                            by Seb932
                                            i'would like to fix my not working LG 49UB850V tv.
                                            Symptoms:
                                            -AC plugged in, Standby LED not working
                                            -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
                                            Checked already:
                                            -Powersupply Output in Standby => 3.5V ok
                                            -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
                                            Any suggestions what to check next?
                                            Thanks in advance!
                                            09-14-2023, 06:28 AM
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Jackching
                                            Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                            by Jackching
                                            I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                            04-15-2024, 05:14 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
