hi i have the above model and its power cycling over and over , ive looked a bit into this and people are saying its the screen . it looks to be a common issue with these as there are alot on ebay anyone ever figured out a fix for this or is it a new panel ?
UE70TU7100KXXU cycling
Tags: None
Is the panel yes. Not sure it's fixable. Look through this thread it may be similar enough to help you, not the same model as his was 70nu6900 I believe.
https://www.badcaps.net/forum/troubl...digging-deeperComment
Here's a pretty good dive into it, pretty good explanation of how the shorts can be about anywhere on those lines and results can vary widely, if you check the last comment there's a link to his continue video of it: https://www.youtube.com/watch?v=7HMGyt1nNgYComment
by high-techHello everybody, I could use some help on this one... It's got me guessing...
I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
(B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
(B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
(OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
(OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
9. ground (PWM2) 10. 0.9 volts cycling... -
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 -
by iMuhtasebA2279 (14" M2 Pro | 820-02841)
No power - switches to 20V for a swift moment then starts cycling/switching on all USB-C ports.
Board is clean.. I looked over it three times and found little corroded caps for a display data lines.. replaced them and they have nothing to do with the issue.
Customer is using a branded USB-C to MagSafe cable. I looked for shorts (diode mode) nearly all lines, PPBUS, 3v8_AON, 5V_S2, 1v2_S2, 1v2_AWAKE, 1v8_AON.. and coils around master PMIC and slave PMIC; all reads normal.
I suspected that ISL might be bad, took an educated... -
by dbuergiHi all,
I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw.... - Loading...
