Samsung UE32D4010 Backlight problem, led ok
  • fanaticgames
    • May 2017
    • 138
    • italy
    hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4305
    • Italy - Milan
    Re: UE3204010 Backlight problem, led ok
    manca la marca e il modello è scritto male...
      • 12129
      • U.S.
      on CNM803, check the blu-on/off pin, so meter set to dcv, black probe on chassis ground, red probe on that blu-on pin, check in standby[tv plugged in but off], take note, leaving the probes where they are, power on tv, take note, does the voltage change and what is the voltage.
        • 12129
        • U.S.
        This is an English language only site, at least that's what it use to be.
        • fanaticgames
          • May 2017
          • 138
          • italy
          0v standby
          4,4v power on
            • 12129
            • U.S.
            Re: Samsung UE32D4010 Backlight problem, led ok
            ok, thats seems good.
              • 12129
              • U.S.
              ok, maybe try unhook cable from mainboard to panel, turn tv on, what does it do? is the optical input lit red on mainboard?
              • fanaticgames
                • May 2017
                • 138
                • italy
                if I unplug the display it does the same thing, the backlight goes off after 1/2 seconds, the red light of the optical port goes on normally for a few seconds and goes off
                the image of the display can be seen perfectly and only that the backlight is missing
                  • 12129
                  • U.S.
                  can you clarify, you mean you can see the image perfectly for 2 seconds then it goes off? if so, see if you can still see the image with a flashlight if you look really closely.
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    the display works, the backlight doesn't (it flashes as soon as I turn on the TV and then turns off), if I unplug the power supply from the motherboard the backlight works correctly
                      • 12129
                      • U.S.
                      seems like a mainboard issue.
                      • fanaticgames
                        • May 2017
                        • 138
                        • italy
                        yes what I thought, I put the post maybe someone tried to repair the motherboard without buying a new one
                          • 12129
                          • U.S.
                          you can check mainboard for voltages, video there, not in English but shows what voltages to expect on mainboard: https://www.youtube.com/watch?v=YE_Sx573E_Y
                            • 12129
                            • U.S.
                            there's probably more that go into greater detail on there but the search on youtube isn't that great, you would think it would be better since google owns youtube.
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              if I set the film mode the brightness appears, in the other 2 modes the image is barely visible, is it a problem of exhausted led bars then?
                                • 12129
                                • U.S.
                                turn off any energy saving settings, like eco mode or whatever it might be called, do a simple reset, unplug tv, hold power button for 30 seconds, plug it back in and try it, did you try adjusting the brightness? wonder if a factory reset would help.
                                  • 12129
                                  • U.S.
                                  this seems strange, usually when it's the backlights no mode will work properly.
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    tried another motherboard, it does the exact same thing, I think it's the exhausted LED lamps
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      Yes I know but also because now I noticed that the backlight is shaking cold
                                        • 12129
                                        • U.S.
                                        well, guess its time to strip it down and investigate the backlights, just treat the panel gently, luckily it's a 32 and shouldn't be too hard to manage, can take video or pictures along the way if anything looks like it would be hard to remember how to re-assemble, need to be careful not to rip or stress the panel board connections to the screen.
                                          09-07-2024, 05:50 AM
                                        • sandinemail@hotmail.com
                                          Samsung BN44-00284A Backlight problem
                                          by sandinemail@hotmail.com
                                          Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                          In November 2020 the TV didn´t turn on only flashing red diod on front off TV.
                                          I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                          I changed all capacitors except the main two 450V 100uf capacitors.
                                          The TV has worked pefectly since.
                                          But this week it started to turn off the backlight. Audio on TV still works.
                                          Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                          Any suggestions on what might...
                                          02-15-2023, 05:10 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • Bloopeta
                                          Samsung UE55H8000 Backlight Power Problem
                                          by Bloopeta
                                          Have a Samsung UE558000, which I thought was just going to be a straightforward backlight replacement, as the screen was dark in the middle.
                                          After stripping it down, I noticed it was exactly the same lights out on both sides (see pic)
                                          I tested the strips with LED tester, and no bulbs were out, so I tested the voltage going to the strips, both at the board side, and at the strip.
                                          On Blue, there is 30.5v on pin 3 and 9, but nothing on the others.
                                          Same situation on White, 30.5v pin 2 and pin 8
                                          All caps look ok, anyone any idea?...
                                          01-30-2023, 01:34 PM
