Samsung UE32D4010 Backlight problem, led ok
  • nomoresonys
    • 12276
    • U.S.
    Re: Samsung UE32D4010 Backlight problem, led ok
    probably similar process as here: https://www.youtube.com/watch?v=HFi2slA4ZK8
    • nomoresonys
      • 12276
      • U.S.
      its around 10 years old, so backlight is a pretty good bet, 10 years is a good run for led backlights these days. Even so that tv is probably better than the junk they've been making in the last 5 years.
      • fanaticgames
        • May 2017
        • 138
        • italy
        I will change the led strips
        • fanaticgames
          • May 2017
          • 138
          • italy
          LEDs changed, firmware updated and factory reset done, it works
          • nomoresonys
            • 12276
            • U.S.
            Glad to hear it.
              09-07-2024, 05:50 AM
            • sandinemail@hotmail.com
              Samsung BN44-00284A Backlight problem
              by sandinemail@hotmail.com
              Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
              In November 2020 the TV didn“t turn on only flashing red diod on front off TV.
              I then opened up the TV and found bulged capacitors on the inverter/powerboard.
              I changed all capacitors except the main two 450V 100uf capacitors.
              The TV has worked pefectly since.
              But this week it started to turn off the backlight. Audio on TV still works.
              Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
              Any suggestions on what might...
              02-15-2023, 05:10 AM
            • sansanpartida
              Samsung QE82Q70RAT no backlight
              by sansanpartida
              Hi everyone!
              Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
              My issue: No backlight.
              Model: QE82Q70RAT
              Type No: QE82Q70RAT
              The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
              So hopefully, I can fix this cheaper.
              05-22-2024, 06:56 AM
            • howardc64
              Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
              by howardc64
              TV was fixed just after removing Samsung's rear snap cover.
              This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
              Maybe PSU->backlight connector didn't have a good contact?...
              07-23-2025, 12:34 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
