Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • gbbradshaw
    • Feb 2023
    • 55
    • United Kingdom
    #81
    Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    Originally posted by Diah
    are you heavy weight person lol..... the place were u worked before on u ribbon... i can see there are signs
    if you were slim which i don't think so... then sorry ignore what i wrote. lol
    Hahaha, no I am not fat person, just a normal guy that used to do alot of sports. Not slim, not fat.
    Talking about the u ribbon , i don't see any signs as I have not worked on them, maybe just some fingertips
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4343
      • Italy - Milan
      #82
      Originally posted by gbbradshaw
      I am afraid I have only removed the u ribbon from right side as I ran out of time to do so for the left side aswell
      I will try this tomorrow. So patch 8, then another 8, only from on side of the u ribbon, until it gets fixed? Please look at picture.
      no you' ve not understood, the faulty part of the screen is the right part, so you have to put tape only on right half and not so, you start from far of side and shift 1 pin per time only not 8.. but only 8 pins covered..
      • gbbradshaw
        • Feb 2023
        • 55
        • United Kingdom
        #83
        Ok, I will try. But can you have a look at this video and maybe explain why he has covered like 15 pins at once please?
        https://youtu.be/XCJAx92JwPs
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4343
          • Italy - Milan
          #84
          Some lines can have no influence, the lines to be blocked are the clock lines usually are 8 but can be less, check on the screen's small boards if there are test points named CKVxxx you can also discover to which pins are connected by using multimeter..
          • gbbradshaw
            • Feb 2023
            • 55
            • United Kingdom
            #85
            And how can I find them? I mean, there are no markings on the small boards, just the capacitor numbers C- etc
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4343
              • Italy - Milan
              #86
              if no markings ---> dog penis method (random)
              • gbbradshaw
                • Feb 2023
                • 55
                • United Kingdom
                #87
                How do I know which side of thr u ribbon?
                • gbbradshaw
                  • Feb 2023
                  • 55
                  • United Kingdom
                  #88
                  Dude ! I have found the test points, called TESTa12 TESTb12 . How can I test them? Can you please guide me ? Thanks
                  LE: unfortunately these are not called CKVxx
                  • lotas
                    • Jan 2016
                    • 4620
                    • Russia
                    #89
                    Ckv1,2,3,....
                    • gbbradshaw
                      • Feb 2023
                      • 55
                      • United Kingdom
                      #90
                      Originally posted by lotas
                      Ckv1,2,3,....
                      Great! How should I set my multimeter to?
                      Please can you draw on this picture? I am no professional but I do know how to follow instructions
                      Beep or 20k resistance?
                      • lotas
                        • Jan 2016
                        • 4620
                        • Russia
                        #91
                        Disconnect the U-tubing and measure the resistance at these points (CKV) against ground (on the bar itself).
                        You can also put it on 2K and where the resistance will be underestimated, that CKV is not working.
                        • gbbradshaw
                          • Feb 2023
                          • 55
                          • United Kingdom
                          #92
                          Shouldn't I change the cable to here?
                          • lotas
                            • Jan 2016
                            • 4620
                            • Russia
                            #93
                            Yes
                            • Diah
                              • Feb 2013
                              • 6376
                              after going back to yours Photo
                              it look for me half buffer issue which it caused by didn't match firmware with Panel. there are SPI on the panel it keep "safe" parameter from yours old MB firmware..would be written back to match by Hard reset from MB or update / downgrade firmware on yours replacement MB.
                              • gbbradshaw
                                • Feb 2023
                                • 55
                                • United Kingdom
                                #95
                                And how do I do that hard reset?
                                Edit: I have reset the tv, now trying to update software as the reset did not help.
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  hard reset shoulkd done via service menu... post #38
                                  • gbbradshaw
                                    • Feb 2023
                                    • 55
                                    • United Kingdom
                                    #97
                                    Problem solved ! The tv has finally been repaired.
                                    Solutions:
                                    1: changed the main board , this way I went from having a permanent blue screen with sound to having image + sound but lines on screen.
                                    2. Checked every single one of the capacitors and resistors on the bottom boards, no luck.
                                    3. Covered the first 8 pins of the first part from the left side of the u ribbon, one by one until the total of 8 pins, no luck, i even went up to 15 pins, no change.
                                    4. The fourth and the final step, the solution itself, was the decision of trying to cover the pins from right part of the u ribbon, which are located on the same socket, but on the right side. I started with covering one pin and when I got to cover the 7th pin, the image was 90% clear. Just a few lines on the top but barely noticeable. Because I wasn't happy enough, I have decided to go more, one by one ,until the 15th pin where the image was perfect.
                                    I have covered the pins with normal transparent tape, as the black insulation tape was too thick and I couldn't stick the u ribbon back in. Hopefully, this tape will last at the board temperature . Fingers crossed.
                                    Thanks to all for your help. I have gained so much information over here. I couldn't have done it without you guys. Really appreciate it !
                                    • gbbradshaw
                                      • Feb 2023
                                      • 55
                                      • United Kingdom
                                      #98
                                      Here are the informative pictures.
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        Nice work being persistent paid off. Good job
                                        • gbbradshaw
                                          • Feb 2023
                                          • 55
                                          • United Kingdom
                                          #100
                                          Hi everyone.
                                          I had to reopen this thread as now I've encountered another problem with the tv.
                                          Basically the tv works but the brightness Is at its lowest possible and the screen flickers. I can see the image in the dark room but only then. I have tried to lower the brightness and also turned the automatic brightness off.
                                          The things I've tested are:
                                          -plugged of the pcb and start the tv, but still same issue
                                          -started the tv without the led connected plugged in, same
                                          -tested the power that comes out from the power board to the led connector. I am getting 286v on the first pin 1+ and just that, the rest shows 0 voltage. With or without the led connector in.
                                          Is this likely to be the power board needs replacing?
                                          Please see the image attached with the power board.
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
