Samsung un65eh6000 backlight issue
  • bstewara
    • Jun 2019
    • 40
    Hi All,
    I have a Samsung Un65eh6000 with a backlight issue.
    The original issue was backlight current was present but led strips did not light
    I tested the backlights and all tested to be working properly.
    I assumed then that the power supply was not sending current to the led strips.
    Power supply board part number BN44-00560A.
    After checking voltages it appears that current output at connector CNL802 was outputting the correct current 189 VDC on pins 1,2,6, and 8.
    The issue then was there was no ground on the connector 4,8,11, and 12.
    I then created a case ground on pins 4,8,11, and 12 and all backlights came on.
    My issue now is they're at approx. 30% and will not ramp up to normal range?
    Would anyone have any suggestion to what is limiting the backlights to ramp up to normal operating parameters?
    Thanks in advance
    • 12088
    • U.S.
    Re: Samsung un65eh6000 backlight issue
    so are you trying to turn them up in the menu?
    • lotas
      • Jan 2016
      • 4512
      • Russia
      You have a strange solution to the problem - short-circuit 4,8,11, and 12 to the ground of the TV.
        • 12088
        • U.S.
        lol, I didnt get that part.
        • bstewara
          • Jun 2019
          • 40
          No
          I’m just trying to figure out a solution.
          Try to understand why the backlight come on when grounded to the chassis.
          Backlights have been tested 2x. Just not sure what controls the backlight circuit.
          • R_J
            • 9534
            How are you testing the backlights? The problem is very likely one bad led in the circuit causing the protection to shutdown the backlight circuit.
            • bstewara
              • Jun 2019
              • 40
              Using a TKMDR Backlight tester.
              Tested each bead then each strip 63vdc each strip. 3 strips per circuit 189vdc per circuit.
              They all come on but can’t seem to get the system to ramp up?
              • R_J
                • 9534
                The tester outputs a max 30ma, under normal operation the led's usually draw over 150ma,
                led's often fail under higher current.
                the only way to test the led's with the tester is to check each one individually and even then that might not work.
                • bstewara
                  • Jun 2019
                  • 40
                  Thank You RJ
                  I may just try another set of strips.
                  Regards
                  • R_J
                    • 9534
                    If you are going to open the panel, you can operate the back lights without the panel installed, so make sure the backlights are all working before reinstalling the lcd panel, this will reduce the chance of breakage.
                    • alfatv
                      • Sep 2020
                      • 353
                      Originally posted by bstewara
                      Hi All,
                      This is voltage, not current.
                      By grounding other sides of the strips, there is no current limiting in place, you can damage the strips by doing this. However they might on last legs anyways based on your description.
                      • Cornito
                        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                        by Cornito
                        Hello Team,
                        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                        08-08-2024, 08:09 AM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
                      • soler88
                        Samsung UN46H5203 backlight issue - stumped
                        by soler88
                        I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
                        I disconnected the main board from the PS but still no backlight.
                        Looking at previous threads, nothing is jumping out at me and I'm stumped.
                        Here are the voltage measurements:
                        ON STATE
                        CNM803 on PSU from Main
                        Pin 1 A13v - 13.09v
                        Pin 2 OD_UD - 3.3v
                        Pin 3 A13v - 13.09v
                        Pin 4 BLU_PWM - 1.6v
                        Pin 5 A13v...
                        10-09-2024, 07:28 AM
                      • kdaniel
                        Samsung UE55JU6800 Issue with new backlight
                        by kdaniel
                        Recently bought faulty Samsung UE55JU6800 which when collected was faulty and was not turning on or at least there was jo picture on it. After taking it home and turning it on the TV was working fine.
                        However, there were dark spots all around just like faulty backlight looks like. After replacing the backlight for new one, there is the same issue where black spots can be seen at the point of each led.
                        Any advice ore recommendations what could be the possible issue? Could it be cheap backlight i got from china?
                        Thanks in adv...
                        11-03-2022, 06:12 PM
                      • Cornito
                        TCL 65C715 backlight issue
                        by Cornito
                        Hello team,
                        I'm back with another topic.
                        It's a 65C715 TCL tv with backlight issue.
                        But the problem is a bit strange.
                        When I took this tv from the marketplace backlight didn't work but picture was ok.
                        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                        Putting all back together the tv worked fine for weeks. => Contact issue??
                        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                        06-09-2024, 02:24 AM
