TP.MS3463S.PB711 Start up loop
  • MarkC1970
    • Feb 2022
    • 22
    • Wales
    I have a TP.MS3463S.PB711 that is boot looping. Immediately you apply power the standby LED turns white but it doesn't start up. After about 30 seconds it goes red for a second and then back to white.
    I have 40v for the backlight but no boost. Pin 8 (PWM) for the backlight boost is 137mV so it is off. DB101 is generating the 12v rail. The 5v rail is produced on LD1, the 3.3v is present on UL1 and the 1.2v is on LD2.
    We appear to have all the power rails, no short on the backlight or anywhere else I have checked but she will not start up. Any ideas? Thanks.
  • lotas
    • Jan 2016
    • 4536
    • Russia
    Re: TP.MS3463S.PB711 Start up loop
    Maybe it's in the firmware.
    • MarkC1970
      • Feb 2022
      • 22
      • Wales
      Thanks. I could take the NAND off and get an adapter for my TL866ii but I can't find a NAND dump for my particular model of TV. Any idea how specific these NAND dumps are? I am thinking about screen resolution etc. Cheers.
      My TV is a Sharp LC-32CHF5111K
      • lotas
        • Jan 2016
        • 4536
        • Russia
        There is no Nand, there is SPI Flash 25Q64, put your dump here, I will check it.
        • MarkC1970
          • Feb 2022
          • 22
          • Wales
          I thought it was in the TSOP48 and the underside.
          Well that is interesting because this board has no IC populated there and neither does a donor board that I harvested some backlight parts off but never touched.
          I wonder if there are different versions built on the same PCB?
          I can't seem to embed the picture but it is at https://photos.app.goo.gl/56uAEviUx19RbNVKA
          • lotas
            • Jan 2016
            • 4536
            • Russia
            Yes, it turns out there are two versions, with spi and nand firmware.
            • MarkC1970
              • Feb 2022
              • 22
              • Wales
              Any idea where I can source the NAND dump so I can reflash it? Pretty good chance it is that.
              • Diah
                • Feb 2013
                • 6355
                search the form we do have user from Philippine faced same issue.. it was one smd Dc-DC regulator close to main cpu defect.
                • Willail
                  • Jan 2016
                  • 29
                  • France
                  Hello Lotas,
                  How are you? I have a pb with my sharp TV LC48CFE4042E, mainboard TP. MS3463S.PB711.
                  If i send you the dump of the spi fash of the TV, could you repair it?
                  • lotas
                    • Jan 2016
                    • 4536
                    • Russia
                    Originally posted by Willail
                    Hello Lotas,
                    Okay, show me your dump, I'll take a look.
                    • lotas
                      • Jan 2016
                      • 4536
                      • Russia
                      Can't post the dump?
                      • Willail
                        • Jan 2016
                        • 29
                        • France
                        Hello Lotas
                        This is the fileSharp 25Q40 LC48.rar
                        • lotas
                          • Jan 2016
                          • 4536
                          • Russia
                          Hello Lotas
                          Try.
                          There are two dumps in the archive, the original one is fixed, the second one is also fixed and cleaned (nvm -FF...)​ The file name should be 25Q64, not 25Q40.
                          • Willail
                            • Jan 2016
                            • 29
                            • France
                            Hello Lotas,
                            Thank a lot for the two dumps. I will test them quickly.
                            Could you help me to fixed my graphic board Radeon HD7870 2G?
                            The graphic board was not use during 1year, then i used it 1 month ago, in my pc, no post and black screen. I check the mosfets, some of them seem to be bad but when i remove them and test them, they are good.
                            I don't understand why i have always shorts on the pcb when i test Drain and Source (Mosfets removed). Do you think that the gpu is shorted?
                            Some pictures of my graphic board
                            • Willail
                              • Jan 2016
                              • 29
                              • France
                              Try.
                              Hello Lotas
                              Thank a lot for your dumps. The first corrected dumb works well.
                              Thank you
                              • lotas
                                • Jan 2016
                                • 4536
                                • Russia
                                Hello Lotas
                                Thank you
                                Ok!
                                • Nagy Daniel
                                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                                  by Nagy Daniel
                                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                  So, I generated a table with AI so I can...
                                  03-04-2025, 08:24 AM
                                • Takeatry
                                  Yet another Samsung QLED Boot Loop
                                  by Takeatry
                                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                  10-04-2024, 02:57 PM
                                • Victor Moreira Silva
                                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                  by Victor Moreira Silva
                                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                  Well, my decice specs are the following:
                                  Model: Acer Nitro 5 AN517-54-55T5
                                  CPU: Intel Core i5-11400H
                                  GPU: NVIDIA GeForce GTX 1650
                                  Motherboard: GH51G LA-L181P Rev:1c
                                  The symptom:
                                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                  05-26-2025, 10:49 AM
                                • lefetylorant
                                  Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                  by lefetylorant
                                  Hello Everyone,
                                  Long story short, I got this unit for very cheap.
                                  I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                  I've performed some measurements:
                                  - 20V rail perfectly...
                                  09-14-2023, 05:05 AM
                                • bimole
                                  Weird behavior on 3.3V rail of a CORSAIR CX600
                                  by bimole
                                  A colleague gave me an apparently ill CORSAIR CX600.
                                  He told me that he heard a banging noise, and smelt the magic smoke.
                                  After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                  I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                  It's another story on the 3.3V rail...
                                  I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                  02-13-2025, 04:49 AM
